setting daytime running lights and safe home - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 12th, 2012, 08:35 PM
Local Time: 11:28 PM
United-Kingdom setting daytime running lights and safe home
I have just got my first mini, a countryman 2012 model. It is great, but I cannot get the info/set to set up my lights for daylight running or even to do the safe home thing. I might have missed something basic like should I leave the light stalk on lights all the time.... I am sure this is a really simple thing....
but help!!
Old Feb 13th, 2012, 06:28 AM
Russia Male
From the 2011 manual, probably the same for yours:
Pathway lighting
If you activate the headlamp flasher after switching off the ignition with the lamps switched off, the low beams come on and remain on for a certain time.
The setting is stored for the remote control in use.
Setting the duration or deactivating the function
1. Switch on the ignition.
2. Briefly press the button in the turn signal lever repeatedly until "SET/INFO" is displayed.
3. Press and hold the button until the display changes.
4. Briefly press the button repeatedly until the symbol and "SET" are displayed.
5. Press and hold the button until the display changes.
6. Briefly press the button repeatedly until the display shows the illustrated symbol.
7. Press and hold the button until the display changes.
8. Briefly press the button to select:
> The function is deactivated.
> ...Select the appropriate duration, e.g. 40 seconds.
9. Press the button for a longer period. The setting is stored.
Activating/deactivating daytime running lights
6. Briefly press the button repeatedly until the display shows the illustrated symbol, arrow.
> Daytime running lights activated.
> Daytime running lights deactivated.
LED Daytime running lights Jar-i Second Generation MINI Exterior 2 Oct 30th, 2010 02:23 PM
Daytime Running Lights rastariki First Generation MINI Exterior 51 Apr 4th, 2005 09:48 PM
Daytime Running Lights TJRicer First Generation Faults & Fixes 2 Jul 13th, 2004 09:20 PM
Daytime Running Lights AMT General Discussion 12 Nov 4th, 2003 10:18 PM
Daytime Running Lights? Yes or No? mjmarquez General Discussion 52 Oct 12th, 2003 05:06 PM
