My JCW'10 doesn't detect when a passenger is on the seat. - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Interior & ICE > Second Generation Interior & Ice
Passenger seat mechanism different to drivers? Bossworld Second Generation Interior & Ice 5 Mar 12th, 2014 01:50 PM
Seat base not locking in position for rear passenger entry Technik21 Second Generation Interior & Ice 0 Jun 20th, 2013 09:26 AM
Passenger Seat Belt 01sturner General Discussion 1 Feb 2nd, 2013 11:57 AM
Unable to remove rear seat in '03 base Doorothie First Generation Faults & Fixes 0 Aug 23rd, 2012 07:23 PM
Passenger seat belt jamming in heat jbgg First Generation Interior & Ice 0 Aug 20th, 2012 05:38 PM
Old Feb 18th, 2014, 08:44 PM
Local Time: 04:55 PM
Mexico
Exclamation My JCW'10 doesn't detect when a passenger is on the seat.
Hi,
I was viewing that when someone rides on the passenger seat it doesn't detect that the passenger doesn't have the seatbelt on, so I don't know if that's common in all the mini coopers JCW.
BR,
Old Feb 18th, 2014, 09:07 PM
Local Time: 10:55 PM
If your car has JCW Recaro seats, they do not have an occupancy sensor and so the computer of the car has been programmed not to check the passenger seatbelt.
If you have standard Mini seats (which do have an occupancy sensor), the passenger seatbelt should be checked.
Old Feb 18th, 2014, 09:37 PM
Mexico
I have the standard Mini seats but what I'm looking is that there's a missing cable that connects to the lock of the seat belt and in the driver's side it has that cable.
Do you know from where is supposed that cable connects?
Thanks,
Old Feb 19th, 2014, 10:12 AM
The cable from the seat belt pre-tensioner travels under the seat and joins the other seat cables (airbag, seat heaters, occupancy sensor) at a multi-plug that is fixed under the seat base - each individual cable has a socket on the end of it and they all slide into a small box so that one plug from the car's floor connects to all of them.
The photo below shows the empty box under a Recaro seat, but the parts are the same under a normal seat. You can't really see them with the seat in the car.
To take the seat out:
- disconnect battery and wait ten minutes, so you don;t risk setting off the seat side airbag;
- slide seat forwards and backwards to get at four Torx bolts holding the fixed seat runners to the car's floor;
- tip up the front of the seat a bit and the electrical connection is visible;
- to remove the connection, slide the locking part to the side and the plug will be ejected (the last two photos show the black locking part unlocked and then locked).
ID:	169561   Click image for larger version
ID:	169569   Click image for larger version
ID:	169577   Click image for larger version
ID:	169585   Click image for larger version
The Following 2 Users Say Thank You to Angib For This Useful Post:
Tags: , ,
» Recent Threads
Bought 2003 after 5 yrs of sitting; help!
Today 06:59 PM
Last post by Colin RedGriff
Today 09:09 PM
1 Replies, 73 Views
2015 Countryman
Aug 31st, 2014 12:59 PM
by Sophia7
Last post by Jenna704
Today 08:21 PM
2 Replies, 549 Views
headlight problem 😕
Aug 7th, 2014 11:30 AM
by gadger
Last post by sharpster74
Today 07:53 PM
1 Replies, 354 Views
tempremental xenon headlights
Aug 29th, 2014 08:38 PM
Today 07:45 PM
2 Replies, 511 Views
Which rear wiper
Sep 25th, 2014 07:14 PM
by moblies
Last post by Wheelnut3104
Today 06:55 PM
1 Replies, 321 Views
2011 mini clubman temperture sensor
Today 06:33 PM
by S17cky
Last post by S17cky
Today 06:33 PM
0 Replies, 58 Views
Resonant noise - Mini One D 2006
Today 02:04 PM
Last post by vlado.rekso
Today 02:04 PM
0 Replies, 119 Views
2006 1.4 Mini One D Idle Knocking Noise Just purchased.
Mar 4th, 2013 08:20 PM
Today 01:46 PM
1 Replies, 1,813 Views
how do i reset the airbag light?
Sep 1st, 2006 08:43 PM
Last post by jamesslittle
Today 01:43 PM
7 Replies, 40,601 Views
Bristol Chat
Mar 6th, 2006 03:49 PM
Today 01:40 PM
15 Replies, 372 Views
Mini one speakers
Sep 22nd, 2014 11:50 AM
by Giddzz
Last post by Widgey
Today 01:35 PM
1 Replies, 221 Views
de-cat my miltek or remove resonator?
Aug 18th, 2014 08:52 PM
Last post by marque
Today 01:14 PM
3 Replies, 554 Views
Recommended Spark plugs?
Today 05:54 AM
Last post by marque
Today 01:11 PM
1 Replies, 139 Views
Need advice on what a mechanic "said "
Sep 24th, 2014 05:55 AM
Last post by marque
Today 01:07 PM
5 Replies, 1,969 Views
Mini Cooper S Parts program
Today 02:46 AM
Last post by marque
Today 01:06 PM
1 Replies, 186 Views
Resources
Today 01:00 PM
by Garrus
Last post by Garrus
Today 01:00 PM
0 Replies, 90 Views
Were these rims worth it?
Sep 3rd, 2014 08:17 PM
Last post by Garrus
Today 01:00 PM
10 Replies, 1,029 Views
2nd hand mini experience
May 22nd, 2014 05:57 PM
Last post by Garrus
Today 12:58 PM
7 Replies, 1,632 Views
Changing Battery in the Key???
Apr 20th, 2007 02:54 PM
Last post by Garrus
Today 12:21 PM
13 Replies, 52,180 Views
Mini Cooper 1.6 R56 oil in spark plug tunnels
Yesterday 09:59 AM
Last post by i-CONICA
Today 12:14 PM
1 Replies, 227 Views
Wheel & Tire Center
