R56 change date format - MINI Cooper Forum
Second Generation Interior & Ice
post #1 of 7 (permalink) Old May 12th, 2014, 09:42 AM Thread Starter
Local Time: 12:21 PM
Quoted: 11 Post(s)
Hi there - anyone know how to change the date format from American MM/DD/YY to English DD/MM/YY for an R56. it doesnt have the Visual Boost - see photo.
Name:	Date format.jpg
Mid Life Mini is offline
post #2 of 7 (permalink) Old May 12th, 2014, 02:32 PM
Cooper S Jon's Avatar
Quoted: 1 Post(s)
have you looked in the setting menu then clock/date icon,on my S with sat nav gives me the option to change date format..
Cooper S Jon is offline
post #3 of 7 (permalink) Old May 12th, 2014, 02:39 PM Thread Starter
Quoted: 11 Post(s)
Thanks - this car does not have the Sat Nav, all done through the radio bit as per the picture.
post #4 of 7 (permalink) Old May 12th, 2014, 07:33 PM
Local Time: 11:21 AM
Quoted: 39 Post(s)
That can definitely be reset via the Settings menu, as I did it on my non-Visual Boost car.
Have you got the engine running, not just the ignition on, as several settings are only accessible then?
Angib is offline
post #5 of 7 (permalink) Old May 12th, 2014, 08:42 PM Thread Starter
Quoted: 11 Post(s)
Thanks, I'll pass that on, it's not my car.
post #6 of 7 (permalink) Old Feb 2nd, 2015, 05:04 PM
Changing date format
Apologies new to this so apologies if I am missing something but did you managed to change the date format I am having the same problem. Thanks
Adventurer is offline
post #7 of 7 (permalink) Old Feb 2nd, 2015, 05:45 PM
Quoted: 39 Post(s)
The usual problem in doing this is not having the engine running - just having the ignition on is not enough.
Angib is offline
air filtter change cooper D R56 den123 Maintenance & MINI Care 3 Mar 12th, 2013 02:07 PM
r56 sump cover oil change den123 Maintenance & MINI Care 0 Dec 24th, 2012 10:50 AM
R56 MCS Reverse light bulb change in rear light cluster Ryanjdover Maintenance & MINI Care 1 Oct 13th, 2012 04:39 PM
