06 S, Aircon not cold - MINI Cooper Forum
Second Generation Interior & Ice
post #1 of 4 (permalink) Old Aug 5th, 2014, 09:43 AM Thread Starter
Local Time: 04:47 PM
Pressing the "*" button and selecting "MAX" so the display reads "LOW" produces lots of fan noise, but only ambient temp air...
The engine idle drops a little and then picks up.
I cannot hear the clutch engaging.
I suppose if there is a lack of gas, then the pressure switch will not allow the clutch to engage?
Looking to get the system vac'd, dye tested and gassed.
Anyone had a similar issue?
originalracingsnake is offline
post #2 of 4 (permalink) Old Aug 5th, 2014, 07:07 PM
Local Time: 05:47 PM
Quoted: 83 Post(s)
Sounds like classic no aircon gas, possibly holed condensor.
k3fus is offline
post #3 of 4 (permalink) Old Aug 6th, 2014, 07:44 AM Thread Starter
That is what I thought. Many thanks. Will get a specialist to check it all out.
post #4 of 4 (permalink) Old Aug 10th, 2014, 08:47 AM Thread Starter
Resolved.
Took the car to my aircon guy who pushed some gas in it, leak tested it, then vacuum'd, then vac tested it. All good. So the gas was escaping through the rubber hoses and it seems the PO was not bothered about getting it tested and regassed.
Once filled with gas and oil, it was spun up and the air con was nice and cold. Job jobbed.
Mini One start from cold noise MartinAnderson Maintenance & MINI Care 0 Feb 24th, 2014 06:19 PM
Intermittent xenons, dash lights and aircon!! L_Sutts First Generation Faults & Fixes 0 Dec 29th, 2013 09:46 AM
Problems with aircon Challo First Generation Interior & Ice 0 Dec 21st, 2012 06:12 AM
rattle. revs up and down, cold start, backfire, jerking misterdarkness Second Generation Faults & Fixes 1 Oct 20th, 2012 12:02 AM
53 Cooper S Aircon issue Corry First Generation Interior & Ice 1 Aug 6th, 2012 06:30 PM
