I'm having an issue with my heater that's a little odd.
Regardless of driving or idle, the heat will not work in Auto or specifying the heat myself. I decided to try every possible button combination to see if anything would make it work, and I found that if in "Auto", I move it from "Lo" to "High" as the airflow changes from coming out of the front facing vents to the lower vents, there's a very brief moment of *hot* air, before it switches to the bottom vents and becomes ice cold again.
I've tried checking the fuses, none appear blown. I've checked coolant levels, appear fine there.
I was wondering if there's any other inexpensive things I might try before taking it back to the dealership?(it's no longer under warranty).
Thanks in advance for any help!
