Heel and toe help wanted. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 16th, 2007, 05:01 AM
Local Time: 04:34 PM
The R56 brake is so sensitive that whenever I attempt a heel and toe, the car goes jerky-jerky. What's the trick if there is one? I have only 200 miles on it so far and maybe I need lots of practice.
Thanks.
Old Jul 16th, 2007, 08:48 AM
caesar's Avatar
Local Time: 12:34 AM
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
Once you get a few more hundred miles on the clock, then the brakes become less sensitive. I would suggest giving them a bit longer to bed-in and start practising then.
Old Jul 21st, 2007, 01:29 PM
Local Time: 06:34 PM
I have the same complaint about the brakes and now with 800 miles on the clock the problem remains. A smooth heel and toe downshift is impossible for me. Are alternate pads available?
Old Aug 1st, 2007, 04:14 PM
medilloni's Avatar
The Stig's Dad
England Male View medilloni's Dark Silver & White 2nd Gen MINI Cooper S Profile
Found the same problem myself - though by changing my style a wee bit it helped.......
Some take their foot (heel) off the floor, using the ball of their foot for the brake, the side or flat of the foot for the accelerator, which I used to do.
I now find it easy and comfortable to lower my seat a little (so you're attacking the pedals straight on as opposed to 'from the top'), keep your heel on the floor, use the ball of the foot for braking and the side of the foot for the gas pedal. With the sport button 'on', the power is availlable nearer the top of the pedal travel so there's very little movement and ankle-bending involved to hit the right revs. It's now nice and smooth and didn't take too long to get used to - the heel planted on the floor really helps to keep it all smooth.
Hope this helps.
By the way, my feet are a size9 - I pity those with bigger plates!
"He fell for her like his heart was a mob informant, and she was the East River."
Old Aug 2nd, 2007, 12:25 PM
stuvoi's Avatar
Cor that sounded very complicated.
I'll have to train some mice to operate the pedals for me - my feet are bigger than a 9
Old Aug 2nd, 2007, 03:32 PM
Local Time: 11:34 PM
Hope this helps.
My heel is always in the air. I think the most important bit of the whole process (excluding me) is the shoes that I am wearing. Considering you are only just on the brake pedal, some shoes are downright dangerous! (If you are using heel and toe in anger!)
What I cant understand is when I have seen drivers actually using their heel and toe. Heel on accelerator and toe on brake. I have never found a car with pedals angled to make this possible!
Maybe its just me! It looks easy on film, but doesnt make sense when I have tried it myself. (not that the sides of my feet cause me a problem!)
...Mad
Old Aug 2nd, 2007, 03:38 PM
still learning
Scotland Male
you guys seem to going to a lot of trouble to achieve this style of driving.
what's the benefit ? and should I be trying to do it ?
Old Aug 2nd, 2007, 04:00 PM
newyorkaddict's Avatar
The Second Coming........
United Kingdom Male View newyorkaddict's Classified Ads
i learned heel-toe in my works van it is all about practice, but when you get it sorted, you find some short little blast journeys, can be done in a lot quicker time sacrificing a bit of extra fuel in the mean time though. one journey i have found this good on is on a back road from where i live South Molton, Devon to Tiverton, Devon, going through a place called Rackenford (just in case anyone wants to see it on a map) its a lovely bit of road, almost made with Cooper S's in mind. I have noticed heel-toeing it i can go 3 minutes quicker then my Civic Type R using the same method.
Old Aug 2nd, 2007, 06:58 PM
Arnbut's Avatar
Manic Hill-Dweller
United States Male
Since track activities basically come down to two actions, floor-it and brake, minimizing the transition times between the two can shave valuable time off your laps.
Go in hot, brake at the last second, get back on the gas-gas-gas-gas-gas-gas, brake, gas-gas-gas, etc.
If you're very good at it, you can save a quarter second or better at times per transition. But, mind you, only if you're good. If you're not good, the lap feels faster (because of the difficulty doing the maneuver) but your time will be slower.
Our classroom instructor the other day used to race in NASCR circles. His method was more of a rolling action with his very big shoe --- worked well in his Corvette.
My attempts at this with a size 14 shoe were, ummm, comical at best.
Safety fast,
Bill
Old Aug 2nd, 2007, 08:16 PM
still learning
Scotland Male
thanks guys, is this a similar concept to "left foot braking" and if so what is the best ?
Old Aug 3rd, 2007, 12:14 PM
medilloni's Avatar
The Stig's Dad
which is the best doesn't really apply Iain, as Arnbut says, heel and toeing is to make the downshift smoother and faster - left foot braking is really a cornering technique, or used to create/uncreate stability in bends. (Well, you can combine the two, but for simplicity's sake.......)
Left foot braking is the (sometimes black!) art of using the brake with your left foot whilst still using the power with your right foot - this can be used to help bring the back end of the car round if the front is running wide - so power is being transmitted to the front wheels and the rears should lose some grip due to the brake being applied.
Done well it can help to stabilise an unsteady car on very high speed bends, or maybe help to swing the rear of the car around bends on loose surfaces, such as snow, dirt, leaves and families of dead hedgehogs. It has also been known for it impress some young girlies and people-that-wear-baseball-caps-that -point-to-the-sky-and-say-'whatever'-a-lot.
Truth of the matter is, it's:
a) Difficult to learn safely on public roads. Don't do it
b) Likely to go through a set of brake pads in no time, discs in less time, tyres even less time - and underpants are usually soiled within 1.8 seconds.
Seriously, it's hardly likely to be useful in road driving situations - but great fun to learn, why not try a day at a Rally School? It's cheaper in the long run!
Cheers,
John
Old Aug 3rd, 2007, 12:32 PM
3rdpillar's Avatar
United Kingdom Male View 3rdpillar's Chili Red & White 1st Gen MINI Cooper S Profile
Sentiments echoed
Old Aug 3rd, 2007, 12:43 PM
Local Time: 02:34 AM
Turkey
left foot breaking
buy an auto then you can left foot break all the time its how people like Russel Brooks and Jimmy McRae learnt as it was not usual for UK drivers of the time (sorry showing my age!)
Old Aug 3rd, 2007, 01:23 PM
thrud's Avatar
United Kingdom Male View thrud's Laser Blue & White 2nd Gen MINI Cooper S Profile
As a related alternative to heel and toe, I use sustained revs at each downshift to provide a smooth changedown. That is I brake, then move to the accelerator briefly before letting the gear back in. This is more suited to general driving when you have more time to move your foot between pedals rather than true hell and toe'ing. Just provides smoothness rather than the potential for quicker times.
Paul
  #15 (permalink)
Old Aug 3rd, 2007, 02:15 PM
Arnbut's Avatar
Manic Hill-Dweller
United States Male
One of the many things you'll pick up at a track school is that there's different ways to induce a bit of oversteer. If your apex was a bit dodgey, sometimes a momentary let-up on the throttle will correct the rear end for more turn-in.
I like to do this on very wide (deserted) on-ramps, especially in the rain. Wicked fun...
Like thrud said though, smooth is good. Get smooth laps first until smooth is second nature. Smooth begets fast, fast begets clever, clever begets really fast.
Safety fast,
Bill
Heel and toe problem Hubert First Generation MINI Tuning 23 Sep 30th, 2003 05:13 PM
Favorite pedals for heel toe action??? DJcooper First Generation Interior & Ice 2 Jun 25th, 2003 01:26 PM
Exercises for your heel and toe rei00 General Discussion 3 May 24th, 2003 07:23 PM
Heel and Toe? mikegre1 General Discussion 43 Mar 10th, 2003 05:32 PM
Heel & Toe scollins First Generation MINI Cooper 13 Feb 25th, 2002 08:16 AM
