DSC and LSD question - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 13th, 2007, 04:08 PM
Local Time: 12:36 AM
England
Just a quick question. If you ordered a car with both the LSD and DSC options, would the two features conflict with eachother? Are they both doing the same job?
Old Nov 13th, 2007, 04:50 PM
Paul's Avatar
MINI2 No.1
Local Time: 11:36 PM
England Male
They do different jobs and play nicely together.
Old Nov 13th, 2007, 05:09 PM
Nath316's Avatar
I'm avin 'oops
Send a message via MSN to Nath316 Send a message via Yahoo to Nath316
England Male View Nath316's British Racing Green & White 2nd Gen MINI Cooper S Profile
have DSC on Pepe and love it when on or off depending on how brave I am feeling
More Air + More Fuel = More Power!!!!!!!!!!!!!!!!!!!
Old Nov 13th, 2007, 05:23 PM
Making it add up
United Kingdom Male View Martin F's Laser Blue & Black 2nd Gen MINI Cooper S Profile
The LSD shares the available power between the wheels in such a way as to maximise the power to the wheel with the best grip. The DSC manages the throttle opening and applies the brakes to stabilise the vehicle. So they do different jobs and, on a track day for example, you would want the benefits of LSD rather than have the DSC reduce wheel spin by cutting the power or applying the brakes
Old Nov 13th, 2007, 06:28 PM
England
OK, thanks. That makes sense.
One other question. Does the LSD drain any power from the car through any kind of 'transmission loss' as is the case with some 4WD cars?
Old Nov 13th, 2007, 08:10 PM
Hyper Active's Avatar
Local Time: 10:36 PM
England Male View Hyper Active's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile
Nope, there's no power loss
Old Nov 16th, 2007, 08:13 PM
caesar's Avatar
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
As a matter of interest my July 07 MCS has LSD + ASC. (Dealer and I forgot to specify DSC).
As a result of having ASC instead of DSC what would be the disadvantages ?
Old Nov 16th, 2007, 08:22 PM
scone's Avatar
England
I did the same Ceaser and forgot to order DSC, you get the traction control part which limits throttle during wheelspin, but you miss out on the system that brakes individual wheels to stop you losing control of your car.
I remember reading not so long that the EU were trying to make DSC compulsory on all cars as it was so good at avoiding accidents.
Old Nov 16th, 2007, 08:55 PM
caesar's Avatar
Hi Scone.
I'm not unduly worried at not having DSC, but am annoyed the Dealer did not advise me to get it especially as I said to him " are there any other items I should specify to improve safety and performance" before I sign the order.
Old Dec 4th, 2007, 06:49 PM
Factory JCW
United Kingdom Male View neilobe's Classified Ads
So im just going to spec one after many months of deciding..
I know i Deff need LSD, but if i have DSC , will this cut power when im trying to accelerate hard, meaning i have to switch it off all the time??
Factory JCW
Old Dec 4th, 2007, 07:33 PM
caesar's Avatar
Having both LSD and DSC will not cause you any problems, but you can switch off DSC by pressing the button in front of the gear stick. It's ON by default, so if you turn it off and then turn off the ignition and then restart, it will be ON again.
LSD is permanently engaged.
The MCS I used on a test drive did not have LSD, and I noticed a lot of torque steer, the MCS I eventually bought has LSD. As a result I get very few problems with torque steer
Old Dec 5th, 2007, 05:06 PM
Factory JCW
Do you not have DSC on your car as well then?
Having had 4 Cooper S, my last one had LSD on it, it was the supercharged one, Would u really need DSC as i dont want to be accerlerating and having the power snatched from me.
Factory JCW
Old Dec 5th, 2007, 05:49 PM
FergusM's Avatar
Scotland Male View FergusM's Dark Silver & Black 2nd Gen MINI Cooper S Profile
Well u can switch it off...DSC that is, and more litely it is the traction control system that comes as standard that controls the amount of power going through wheels. DSC just saves you when you over cook a corner and loose the back end, it then brakes the wheels individually to try and get car to stop spinning.
I have both and think it is great, on track I'll switch DSC off...in the wet winter days I most definitely like having it there.
another what is it question... hwy61 First Generation MINI Exterior 3 Dec 5th, 2004 07:55 PM
question!?! janie_cakie Canada 6 Mar 2nd, 2004 06:28 PM
Question... FREEZE BOX General Discussion 2 Sep 15th, 2003 10:16 PM
Warm up and cool down question.....sorry for the newb question, I've searched here... Jason2002S First Generation MINI Cooper S 4 Aug 14th, 2003 12:03 AM
