| Second Generation MINI Cooper S MINI Cooper S Late 2006 - Present |
| Don't wan't to steer the thread too off topic but basically if you want to change to standard tyres I think there are kits for the non S Mini variants to get an under mounted spare wheel but the S you can't get one because the exhaust is in the way! However you can buy a kit from Mini that is a non run-flat puncture kit that sits under your boot mat. |
| Took mine in for a coolant leak. Momentum Mini said they will check out the leak and take care of the recall issue at the same time. Turns out the main water pump was leaking so they replaced both water pumps under warranty at 43,000 miles on my 2008 S. |
| Cooper D recall | lab-monkey | MINI Cooper Diesel | 20 | Aug 22nd, 2007 09:52 AM |
| Cooper Recall - Fan | Chris.F | Second Generation Faults & Fixes | 17 | Jul 30th, 2007 06:40 PM |
| Cooper S recall ? | pubert | Second Generation Faults & Fixes | 4 | Mar 27th, 2007 07:10 PM |
| Recall Cooper S | marchamundo | First Generation Faults & Fixes | 3 | Mar 12th, 2004 04:01 PM |
| Cooper Recall | CrazyPhil | First Generation Faults & Fixes | 7 | Dec 3rd, 2003 11:04 PM |
