Random misfire - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 25th, 2012, 03:35 AM
Local Time: 06:40 PM
United States View 971of1000's Classified Ads
Random misfire
I have an 07 mcs with 42k on her. I was coming home from a trip and it started misfiring. I limped it home and pulled the ignition coils and got the plugs out. One of the grounds had bent up and was touching the electrode. I have no idea why it happened but replacing the plugs with factory NGks didnt remedy the problem. My question is what else could it be? I have read possibly the hpfp?
Old Jan 25th, 2012, 02:26 PM
Local Time: 12:40 AM
Hi
It could be the high pressure fuel pump I think there under warrantee on the 2007 MCS might be worth asking.
If the electrodes were touching it may have damaged a lead or the coil. It might be worth trying to borrow one and test it.
Have you got any fault codes from the DME
Random misfire on Gen1 Cooper wunhunglo72 First Generation Faults & Fixes 0 Jan 6th, 2010 09:43 AM
Misfire Bankers First Generation Faults & Fixes 4 Oct 7th, 2009 04:23 PM
P0300 Random/Multiple Cylinder Misfire Detected sam_a156 First Generation Faults & Fixes 0 Apr 10th, 2008 03:43 PM
P0300..Random/multiple cylinder misfire detected?? Rickys'S First Generation Faults & Fixes 6 Nov 26th, 2005 04:59 PM
MCS misfire? Plz help... CARVNIT First Generation Faults & Fixes 4 Jan 8th, 2005 10:36 PM
