Loss of power leads to £4,000+ bill for removing head! - MINI Cooper Forum
Go Back   MINI Cooper Forum > Model Specific MINI Forums > MINI Cooper S > Second Generation MINI Cooper S
Old Dec 13th, 2013, 09:07 AM
Local Time: 05:03 PM
I recently got a warning flashed up on the screen stating 'power loss' - it started misfiring at same time - and the warning suggested I reduce power but OK to continue driving. Since I was 40 miles from home, I gently nursed it back and booked it into the dealer (HR Owen, London) the next day. The dealer has had it for 2 weeks now (!) and have finally advised me that the bill will be over £4,000, most of which is to remove the head, so they can de-coke it and also skim the head.
For a so-called 'quaility' car registered in 2007, that strikes me as unusual - or is it? Anyone else had this?
They're suggesting that it has overheated, yet I received no warning of over-heating.
They also told me it would need a new thermostat housing. When I pointed out that they put a thermostat housing on the vehicle in September (only 4 months ago), they said they wouldn't charge me for that.
But why would it fail after only 4 months??? And has this failure caused the problems with the head/de-coking, perhaps? Anyone know?
Old Dec 13th, 2013, 11:26 AM
Local Time: 06:03 PM
£4000 for a de-coke, skim and head removal seems very expensive!
Makes me wonder if they kept it so long to help justify the excessive bill.
Old Dec 14th, 2013, 11:16 PM
£4000?????????? Did you go to Mclaren or something? How much of that is for parts?
Old Dec 16th, 2013, 03:03 AM
Local Time: 03:03 AM
Australia Male
Australia
If yours is an 'S' they should be doing the walnut shell blasting as its much cheaper!
Old Dec 16th, 2013, 11:46 AM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
To me this sounds well dodgy...
Seems like they've replaced the thermostat housing, which has failed and probably lost some/most/all of the coolant and caused the car to overheat, warping the head - hence why it needs a skim. Odd that it would fail so soon - this would make me wonder whether they actually changed it before... if they did and you paid for the work then you will be covered by the standard parts warranty. This may also cover damage to any other components as a result of the failure ie the cost to remove the head and get it skimmed as it has warped.... all as a result of the thermostat housing failure....
It will probably need a decoke as its an r56 and they all end up needing this to be done - this was probably causing the misfire.
The above two problems aren't the cause for one or the other, they are separate.
£4000 to remove just the head is ridiculous - that should be the sort of total cost for a full head removal decoke not JUST to remove the head. Full head removal decoke is around £4k at BMW - luckily mine was done under warranty.
Worth noting that if you have not authorised them to undertake work, they cannot bill you for it - they need authorisation. What exactly is the bill for?
If the standard mini parts warranty covers other parts when they fail then this may cover all costs to remove the head, replace the thermostat housing, skim the head and reassemble - it is worth checking through the terms and conditions to check this out for yourself. The decoke is a separate issue in my view. It may well need a decoke but this hasn't caused the overheat IMO.
Running 211whp
Old Dec 19th, 2013, 01:54 PM
Thanks for this - all good points. But I'm surprised that if the coolant leaked because of a faulty or badly installed thermostat housing, why didn't i get a temperature warning? The only warning I got was regarding power loss, advising to slow down if I needed to continue (can't remember the exact warning).
Old Dec 19th, 2013, 03:11 PM
Keano's Avatar
JCW 250
Yeah, I don't know tbh as I got an amber warning when it was a bit too high and I understand it would have gone red if it got a lot too high ...
Perhaps the power loss warning was the more serious fault and so the car prioritises whichever is the more significant fault when showing a warning? ie you could have a number of issues but it only displays the most dangerous/significant error/warning??? Im not sure how the car works in this regard....
The amber warning for overheating is a slow down but you can continue warning btw - have you checked the symbols in the manual to check what exactly the display was and what that means?
Running 211whp
Old Dec 20th, 2013, 05:27 PM
I've got the MINI sat nav so the warnings come up on the screen as text.
I do get the symbols coming up on the rev counter as well and if I ever see anything I don't recognise, I pull over and consult the MINI Lights app on my phone, but had nothing about temperature or overheating on either.
Old Dec 21st, 2013, 02:04 AM
Local Time: 01:03 PM
if that was a direct injected engine carbon issues are TYPICAL! manufacturers are not saying much, Audi added warranty time for some. seems some engines are worse than others, new technology not quite perfected yet!!!! many benefits but this one BAD issue since gas does NOT clean the valve stems being directly injected into the cylinders bypassing the intake track
Old Dec 21st, 2013, 03:23 PM
Deep_27a's Avatar
...opinionated!
United Kingdom Male View Deep_27a's  &  2nd Gen  Profile View Deep_27a's Classified Ads
I think you could have got a new engine for that price!
Old Jan 3rd, 2014, 09:31 PM
Blackthou's Avatar
I've read of similar scenarios on other car forums and quite often a common factor is that the car had previously been to a main dealer for either a water pump or thermostat to be replaced. In those cases it was similar symptoms and attributable to an air lock.
Sounds like another case of it to me!
Convertibles are cool
Old Feb 26th, 2014, 10:49 AM
Situation has now deteriorated further:
- Finally picked the car up on 30th Dec (they had promised it would be ready before xmas, but then wouldn't return my calls on 23/24th Dec - all the time charging me £15/day for a so called 'courtesy' car). Original invoice of £4,200 was reduced to £3,800 when I complained about time taken: 2 weeks to diagnose a fault, 5 weeks in total before I got the car back
- Engine was warm when I collected it, and drove 70 miles with no problem, but next day it started missing on cold start-up, and the following day it was missing VERY badly on start-up and I got the same warnings again (engine warning light on plus 'Full power not available....'' on sat nav screen).
- Later that day tried to start it again and it wouldn't start at all - and all the same warning came on again
- in other words, the same problem was still there, and they had taken 5 weeks and charged me £3,800 and FAILED to solve it - plus I was stranded 200+ miles from home
- HR Owen had the car 'recovered' on a trailer to a local dealer, BlueBell BMW in Wilmslow, who diagnosed the problem as a defective high pressure pump and fixed it the same day. I asked them to hold it overnight to do a proper cold start and it was fine. I have since done 400+ miles and the car has been starting and running perfectly
The cost of this high pressure pump replacement was approx £600 (which HR Owen paid after a LOT of arguing) - as against the £3,800 HR Owen charged me. Since then I have advised them that this is not acceptable - their technicians were obviously clueless and were just guessing, and in the end incorrectly diagnosed it and massively overcharged for unnecessary work.
After several emails, we had a meeting with the head technician, head of service dept and the service exec, at which they defended their diagnosis and charges, only offering to 'look further at' the courtesy car charges.
They claimed that the fact that the high pressure pump needed replacing 'was a coincidence' and it was fine when they had the car.
- Re failing to start with the EXACT same symptoms? - another 'coincidence', they claim
- Re having to replace (FOC) the thermostat housing again - it had been replaced in September - they claim it was because the engine over-heated.
- Re their claim that the engine had overheated, I asked them why I received no over-heating warnings on the warning panel or the satnav screen - no answer.
- Re taking 2 whole weeks to diagnose the issue - no answer.
I then took the issue up with BMW who discussed it with HR Owen, but pointed out that ultimately it was not in their remit to force HROwen to do anything - which is fair enough. Since then, because BMW talked to them, HR Owen offered to refund all the courtesy car charges - £266, plus a further £234 to make a total of £500.
If I accepted this it would still mean I've paid out around £3,300 for a fault that should have cost around £600 if diagnosed properly so I've declined their offer. My brother's wife is a solicitor and she's advised that I take them to the local Small Claims Court, which costs very little, and where they are apparently well used to incompetent and greedy car dealers, so watch this space....
(car is a 2007 model Cooper S and has done 61,000 miles, which I believe is average for it's age)
(A small but interesting dealer insight: despite having the car for 5 weeks, HR Owen completely failed to also order and repair some of the waistline trim that they had failed to do when they did some accident bodywork repairs some time earlier. Whilst they had the car they also did a service, but failed to turn off the 'service indicator' light which they have to reset. I'm now having to organise them to fix both issues. In a total contrast, whilst the car was at Blue Bell BMW, they fixed the drivers side windscreen squirter which was blocked and also re-attached the filler cap tether without being asked - both small things I had meant to do, but kept forgetting. It reminded me of the excellent service I used to get when I previously owned BMW's.....)
Old Feb 26th, 2014, 06:42 PM
Deep_27a's Avatar
...opinionated!
Great update Tallon, keep us posted ... Go after them!
Old Feb 28th, 2014, 10:16 PM
Blackthou's Avatar
All too common these days. Very little skill, a lot of guess work and an outrageous bill.
Tags: , ,
» Hot Topics This Week
Mini Cooper N/A rally build - (80 replies)
Has any one got these? - (50 replies)
How to Retrofit the Spacesaver Spare Wheel - (43 replies)
Ok so who has ordered an F56 MCS? - (35 replies)
roof will not retract! - (32 replies)
» Recent Threads
Should i buy a Mini Cooper r50
Feb 14th, 2012 01:09 AM
by MENESS
Last post by jimmy_racoon
Today 03:53 PM
12 Replies, 7,858 Views
R52 A pillar interior trim removal
Yesterday 08:11 AM
Last post by clockworks
Today 01:10 PM
3 Replies, 125 Views
Replacement driver side door handle **new member**
Apr 14th, 2014 10:32 PM
Last post by da8addick
Today 12:22 PM
2 Replies, 197 Views
Drivers Selt Belt PreTensionor / AirBag Fault Light
Today 12:20 PM
Today 12:20 PM
0 Replies, 41 Views
Black rims for 195/55r16 run flats?
Mar 2nd, 2014 03:59 AM
Last post by habi222
Today 12:18 PM
1 Replies, 317 Views
Tyre Sizes
Feb 17th, 2014 10:32 AM
by danb76
Today 12:00 PM
3 Replies, 538 Views
Paint Code for Mini Steel Wheels
Mar 16th, 2014 03:59 PM
Today 11:56 AM
6 Replies, 485 Views
Downgrading Rims
Mar 11th, 2014 09:52 AM
by Timbozy
Today 11:51 AM
6 Replies, 465 Views
Cup holder inserts
Yesterday 06:23 PM
Last post by Mid Life Mini
Today 11:45 AM
3 Replies, 127 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by Captain5691
Today 11:39 AM
20 Replies, 1,115 Views
small business merchant account
Today 08:26 AM
by colnpwl
Last post by colnpwl
Today 08:26 AM
0 Replies, 59 Views
Help, is this a cooper S??
Yesterday 09:29 PM
by markdm
Last post by markdm
Today 01:29 AM
6 Replies, 199 Views
Cooper S Engine Rebuild
Yesterday 07:44 AM
Last post by marque
Yesterday 11:49 PM
1 Replies, 161 Views
O2 sensors in exhaust
Yesterday 06:03 PM
Last post by marque
Yesterday 11:24 PM
1 Replies, 119 Views
Mini Cooper S R56 Timing Chain Tensioner
Feb 24th, 2013 11:53 AM
Last post by MCMULC
Yesterday 09:08 PM
9 Replies, 6,708 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by JohnnyC
Yesterday 07:43 PM
7 Replies, 648 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by mab01uk
Yesterday 07:10 PM
7 Replies, 459 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Yesterday 07:03 PM
14 Replies, 988 Views
Spare wheel 55 plate cooper
Yesterday 01:32 PM
by ajn
Yesterday 07:00 PM
2 Replies, 111 Views
Ľ Wheel & Tire Center
