MCS 2007 coolant help please. - MINI Cooper Forum
Go Back   MINI Cooper Forum > Model Specific MINI Forums > MINI Cooper S > Second Generation MINI Cooper S
MCS 2007 coolant bleed help please. Liquizen Maintenance & MINI Care 1 Jan 21st, 2014 04:57 PM
Coolant leak 2007 Cooper paulmclean General Discussion 2 Oct 1st, 2013 09:02 AM
Fiting an Alloy coolant header tank on Gen 1 MCS ihughes First Generation Faults & Fixes 4 May 14th, 2013 08:39 PM
2007 R56 MCS Turbo blowing/damaged Sharkn3t Second Generation MINI Cooper S 6 Jan 23rd, 2013 10:02 AM
R56 2007 MCS Engine Oil?? AmyVee Maintenance & MINI Care 12 Aug 26th, 2012 04:39 PM
Old Jan 12th, 2014, 01:07 PM
Local Time: 07:11 PM
Hi everyone.
Yesterday while on a drive , one of the coolant hoses failed and dumped water and coolant everywhere. The car was recovered and is now at home.
Tomorrow I will try and get a new hose , refill and hope all is ok.
Is there anything when refilling to be careful of? Any hints and tips?
Where is the bleed valve for the cooling system?
You help would be most appreciated.
Regards
Neil
Old Jan 13th, 2014, 07:49 AM
cjm's Avatar
cjm
Local Time: 08:11 PM
United Kingdom Male View cjm's Classified Ads
Most advice on the forum(s) for Gen 2 seems to be :-
1. drain by separating the hoses under the rad.
2. turn the ignition switch on but not with the engine running.
3. set cabin heater to high temp + low fan speed.
4. carefully pour 50% diluted (G48 for me) blue coolant slowly, squeezing any soft hose parts to release trapped air. System volume is 6 litres
5. when 'max' level is reached screw down the coolant cap + start up.
6. allow to warm up + then let it cool + top up as necessary.
7. bleed with warm engine off; a long screwdriver to the bleed screw on the top of the thermostat (needs looking for!) - careful! max 3 turns or you lose the screw - till escaping air is replaced by coolant. (OR leave it open while filling, but monitor it?)
8. I found I needed to carry diluted coolant to add over the next couple of days till it all settles. An extra bleed is a useful precaution. I topped up first thing in the morning. if possible keep a wary eye on engine temps at all times - I use Android/Torque app.
9. my Gen2 Haynes manual mentions venting the turbo pump by running the engine for 12min but as far as I can see this'll happen anyway + it isn't mentioned on any forum post I've seen...but could be useful as the extra bleed?
Hopefully others will add more info + tips they've found useful. MINIs are prone to airlocks so IMO it has to be done with care and at your own risk as a result of any advice offered...but it's not a 'black art' IMO, nor a 'lifetime fill'
Hope this helps. Remember it's for Gen2 BTW.
Old Jan 13th, 2014, 04:41 PM
Hi.
Thanks for the reply.
Strange things afoot. Have replaced hose. Done as per what people say but now the engine runs but the heater inside is blowing continuous cold air.
Could this mean air block or something worse.
Regards
Neil
» Recent Threads
How much should i sell my mini for?!?!?
Today 06:55 PM
Last post by kimrosexx
Today 06:55 PM
0 Replies, 1 Views
MINI Trailer project?
Yesterday 06:27 PM
by mab01uk
Last post by Angib
Today 04:39 PM
3 Replies, 221 Views
Body Flex - roof wont raise !
Yesterday 08:52 PM
Last post by Angib
Today 04:30 PM
1 Replies, 199 Views
First Left-Hand Drive Driving School
Yesterday 06:46 PM
by mab01uk
Last post by Angib
Today 04:25 PM
2 Replies, 205 Views
Mini JCW buying advice needed!
Today 03:57 PM
Last post by Sidisking
Today 04:04 PM
2 Replies, 92 Views
DIY catalytic coverter questions
Today 03:38 PM
Last post by Burkee52
Today 03:44 PM
1 Replies, 91 Views
Mini Cooper Clubman Power Loss
Jul 19th, 2014 04:14 PM
Last post by marque
Today 03:09 PM
2 Replies, 365 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Last post by kushil
Today 02:46 PM
9 Replies, 1,374 Views
opening the boot - am i being special??
May 4th, 2014 12:20 AM
Last post by Richard of the Hills
Today 01:45 PM
14 Replies, 1,214 Views
Missing fuse
Today 06:55 AM
Last post by mayburyds
Today 08:18 AM
2 Replies, 147 Views
2007 Cooper S "Timing Chain Tensioner Defect"
Feb 14th, 2014 09:49 AM
by igooba
Last post by minifr3ak
Today 08:01 AM
8 Replies, 1,974 Views
Cancel Sat Nav instruction
Yesterday 06:05 AM
Last post by The Nun
Today 07:52 AM
4 Replies, 289 Views
Speedo and tach gauge face plate change
Today 07:29 AM
Last post by karlos9191
Today 07:31 AM
1 Replies, 135 Views
New Online Magazine for Track Day Enthusiasts
Apr 14th, 2014 12:56 AM
Last post by AutoTrackDay
Today 03:23 AM
14 Replies, 2,074 Views
2007 mini cooper s block repair
Today 01:58 AM
by jsroyse
Last post by jsroyse
Today 01:58 AM
0 Replies, 176 Views
Finding Final Stage (Hedgehog) Resistor
Yesterday 08:48 PM
Last post by crackernibbles
Yesterday 08:48 PM
0 Replies, 186 Views
GTI vs Cooper S True Cost to Own?
Jul 21st, 2014 03:39 AM
by hkyktms
Last post by beken
Yesterday 08:43 PM
4 Replies, 843 Views
2009 Radio Software Update
Yesterday 03:30 PM
by Tom_P
Last post by Tom_P
Yesterday 06:27 PM
2 Replies, 219 Views
2nd hand JCW Sytner Coventry
Jul 16th, 2014 06:38 PM
by LA3195
Last post by David T-H
Yesterday 06:10 PM
11 Replies, 1,070 Views
Wheel & Tire Center
