Water in boot where tool kit is - MINI Cooper Forum
post #1 of 3 (permalink) Old Feb 5th, 2014, 11:17 AM Thread Starter
Local Time: 07:39 AM
Question Water in boot where tool kit is
Hi Everyone
Noticed this morning that I had an inch of water in the boot where the tool kit is kept and the shelf that covers this was wet as well. I've had it happen a couple times since Xmas and thought it was condensation but not with this amount of water in the boot.
I have a mini copper s 08 I do open and close my boot a lot for work through the day. The top shelf is not wet so I think it may be coming in near the lock as that looks slightly wet and even abut rusty. Has anyone else had this problem is it common in minis? Advice would be very welcome!
Blondejo is offline
post #2 of 3 (permalink) Old Feb 5th, 2014, 04:48 PM
England
Leaks
I have suffered with water ingress into the spare wheel well but I have a Clubman. This was eventually cured by the dealer under warranty.
I underdstand that the rubber door seals can leak if the bitumastic isn't continuous around the length of the seal.
There can be other causes also such as water leaking along studs or bolts which pass through the bodyshell.
Bozzer
Bozzer is offline
post #3 of 3 (permalink) Old Oct 19th, 2014, 05:10 PM
Originally Posted by Blondejo View Post
Hi Everyone
Same in my 06. Could be the highlevel brake light or the underbody. Is the carpet wet under the rear seats?
originalracingsnake is offline
Tags: , ,
water in rear boot floor tool area jonjeffryes Second Generation Faults & Fixes 11 May 7th, 2015 04:17 PM
Boot full of water, no dash lights,indicator click etc Fuxuper First Generation Faults & Fixes 7 Jan 30th, 2014 06:08 PM
Water under driver's side carpet Hitman70 Second Generation Faults & Fixes 2 Sep 7th, 2013 03:06 PM
R57 Boot issues villiham General Discussion 2 Mar 28th, 2013 01:44 PM
09 cooper convertible boot lid problems Aysh Second Generation MINI Convertible 4 Dec 3rd, 2012 07:59 PM
