High Pressure Fuel Pump - How much????? - MINI Cooper Forum
post #1 of 8 (permalink) Old Feb 13th, 2014, 05:20 PM Thread Starter
Local Time: 02:25 AM
Hi I have an issue with my 2007 Mini Cooper S
it cuts out pretty much straight away from a cold start, and can take 3 or 4 times to start
It also occasionally misfires when putting foot down in normal driving. I believe this may be the High Pressure Fuel Pump.
How much is a new one of these fitted on average? and anyone know any garages near leeds?
Nikki
njsupplies is offline
post #2 of 8 (permalink) Old Feb 13th, 2014, 08:51 PM
Local Time: 01:25 AM
Hi ya you may be able to get a good will clam
http://www.mini2.com/forum/maintenan...fuel-pump.html
marque is offline
post #3 of 8 (permalink) Old Feb 13th, 2014, 09:15 PM
zyo
owt else is just traffic
zyo's Avatar
Don't know about the problem when starting but mine is a 2007 MCS and I used to get a strange misfire now and again, I had several high pressure fuel pumps when it was under warranty, it never did cure it. In May of this year I had a de coke and it hasn't done it since so it looks like mine was a build up.
I know MINI will clean out the head for about 240 ish quid, they use crushed walnut shells I believe as a medium to blast out the deposits. Don't know anyone who has had this done so I'm not sure how successful it is.
zyo is offline
post #4 of 8 (permalink) Old Feb 19th, 2014, 02:02 PM
Mauritius
Hi njsupplies. This sounds exactly like the problem I am having, my mechanic has replaced my fuel pump and still getting the same problem. Its resolved an issue of the car being very juddery when driving especially from cold but am still having the sam issue when starting. You start the car which is fine and then the revs just slowly drop until it stops and there is no saving it by using the accelerator
emmaplu is offline
post #5 of 8 (permalink) Old Mar 23rd, 2014, 03:39 AM
Quoted: 1 Post(s)
Australia
New Zealand
Nikki
We had exactly the same problem with our 2009 MCS about a year ago. The dealer initially thought the problem was with the thermostat and replaced it.
This did not fix the problem and the car was still difficult to start (up to 6 times to get it running). Also the engine would die and then surge dangerously.
The problem was tracked to the High Pressure Fuel Pump and the replacement was fitted. In our minds the dealer gouged us - A$ 1550!! But what are you to do? Pay the money and take the car home with you, or leave it at the dealer!!
We have had no further issues with starting or running.
I hope you have better luck.
SteveAus is offline
post #6 of 8 (permalink) Old Apr 8th, 2014, 04:02 PM
Mauritius
Hi SteveAUS
You are lucky that a new fuel pump has fixed the problem, my dealership had to refer it to BMW as they have no idea whats wrong. Still waiting .......
emmaplu is offline
post #7 of 8 (permalink) Old Apr 9th, 2014, 05:09 AM
Quoted: 1 Post(s)
Australia
Originally Posted by emmaplu View Post
Hi SteveAUS
Yes, this problem seems to be a difficult one to diagnose. I have seen a few posts where dealerships have had two bites of the cherry to find the root cause.
Perhaps you could suggest to your dealer that the HPFP may be the cause and ask your dealer to check the BMW worldwide database. There will likely be several examples for them to compare with your particular issue.
Good luck.
2009 R56 Mini Cooper S: Chili Red, Black Roof, Black Wheels, ASC+T, SatNav, Very Cute!
SteveAus is offline
post #8 of 8 (permalink) Old Jul 9th, 2016, 03:05 PM
Hi I have just joined this forum as I have the same issue, with my mini s convertible 2011, bought 2nd hand from the dealer in part ex. at first the fan/thermostat went, then they thought the AMC unit had gone but after taking it in a third time in as many weeks they have said its the HPFP and as I complained that they failed to identify the root cause of the fault in the first place, they have via BMW offered a goodwill gesture of paying half costs, which still potentially leaves me 550 down! I have read many reports of problems linked to this fault but does anyone know if they have reclaimed all the costs from the dealer? My warranty ended in May this year.
Bel Robertson is offline
High Pressure Fuel Pump failure symptoms genik Second Generation Faults & Fixes 8 Jan 31st, 2014 12:35 AM
high pressure fuel pump leak and head office lies! Shanos General Discussion 0 Nov 29th, 2013 05:24 PM
Weird starting problem / FUEL PUMP, FILTER ? Schakal General Discussion 0 Oct 31st, 2013 11:55 AM
High pressure fuel pump UK/USA differences NJP Second Generation Faults & Fixes 5 Aug 7th, 2013 12:00 PM
Help - High Pressure Fuel Pump leighMCS Maintenance & MINI Care 13 Mar 13th, 2013 01:38 PM
