Esys Coding for R56 Cooper S - MINI Cooper Forum
post #1 of 4 (permalink) Old Mar 22nd, 2014, 08:59 AM Thread Starter
Local Time: 06:48 PM
Quoted: 1 Post(s)
Australia
New Zealand Esys Coding for R56 Cooper S
I'm new to the Mini Forum and would like to ask a few questions.
Has anyone on the forum performed any Esys coding on the R56?
In fact, is it possible using the OBDII cable and the BMW E-Sys programme?
The main reason I am asking is that I own a BMW F30 and have been able to code out the legal disclaimer of the computer system on start up - saves having to press the I-drive controller every time you start the car and allows SatNav and graphical parking sensors to fire up straight away.
I would like to do the same on my wife's Cooper S.
Thanks in advance
SteveAus is offline
post #2 of 4 (permalink) Old Mar 26th, 2014, 03:48 PM
Local Time: 07:48 PM
Cyprus Male
The R56 is similar to Exx BMWs binary-wise so coding will need to be done with NCSExpert. You need SP_Daten files instead of the PSZ (or whatever) for Esys and the program does not need a key to function. In this regard, it is actually easier than E-sys (from what I read). You should be able to use the same INPA-compatible USB/OBD2 cable you use for the F30.
Yes, what you want to do is doable... I suggest you visit Northamericanmotoring to see how to do it.
alexcannas is offline
post #3 of 4 (permalink) Old Mar 27th, 2014, 02:34 AM Thread Starter
Quoted: 1 Post(s)
Australia
Alexcannas,
Brilliant. Many thanks for the reply and the help. I'll check out the link and see if this something I can do.
2009 R56 Mini Cooper S: Chili Red, Black Roof, Black Wheels, ASC+T, SatNav, Very Cute!
SteveAus is offline
post #4 of 4 (permalink) Old Jan 9th, 2015, 02:46 AM
Local Time: 10:48 AM
American Samoa
I new to Copper too. Is the cheap ENET cable you mention above.
Does it fits copper ?
Tony Back is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
Learning to Drive MINIs the Way John Cooper Intended AutoGuide.com MINI News 0 Jul 26th, 2013 06:12 PM
A Look Back at the Three Generations of the Mini Cooper & Cooper S mab01uk MINI in the Media 2 Mar 10th, 2013 10:11 AM
