Head gasket, not always - MINI Cooper Forum
post #1 of 4 (permalink) Old Apr 15th, 2014, 10:32 PM Thread Starter
Kilty
Local Time: 06:06 AM
Just a little help for anyone that has had major head aches with "head gasket"
Started with the usual mayo in cylinder head. R56 N14 2008
Replaced gasket, checked head, did not look like it needed skimmed.
One month later after more mayo and 2 oil changes, still coming back. Not as thick but still present.
Decided to redo head gasket this time got head skimmed.
Exact same result. New bolts were used in both changes. Torqued correctly Correct oil used and not overfilled.
Studied engine diagram as 3 failures on gasket would be as much luck as winning the lottery. Only other place I could see oil / water possibly mixing is oil cooler.
Ordered gasket sets. M11.42.7.557.009 and M11.42.7.557.010 (31.61 for both) cleaned oil cooler and checked cooler and filter housing for cracks, all ok.
Replaced oil and coolant not a drop of mayo has appeared for the last 700 miles.
Dealer told me they have never ordered these gaskets before.
I can sleep again and drive car as it should be driven, with sport on.
Hope this helps anybody in same position.
Kilty is offline
post #2 of 4 (permalink) Old Apr 16th, 2014, 08:18 AM
Quoted: 53 Post(s)
Mayo is not always the sign of head gasket problems, it can build up excessively and clog the engine breather system causing oil leaks and can be caused by the engine not warming up fully due to too many short journeys in cold weather or a thermostat problem, the moisture and condensation that forms due to the combustion process and oil is the mayo.
Now the weather is warming up and more people are using their car on longer holiday journeys the mayo will evaporate and disappear as the car reaches full operating temperature for longer periods.
The Nun is offline
post #3 of 4 (permalink) Old Apr 16th, 2014, 08:44 PM Thread Starter
Kilty
I believe the cylinder head was one fault to start with, the engine had overheated on a 700 mile trip, due to faulty thermostat. It then had cooling fan running in stage 2 as soon as engine started and stayed on for a further 5 mins after car stopped. I was able to clear this after changing thermostat housing with new sensor, but other damage was done, head gasket and oil cooler gasket.
Kilty is offline
post #4 of 4 (permalink) Old Apr 29th, 2014, 06:18 PM
Local Time: 05:06 AM
Ouch that does not sound fun
tschultz is offline
Tags: ,
PANORAMIC SUN ROOF ISSUES -I'm in talks with Mini Head Office UK PLEASE READ/CONTACT LadyUK General Discussion 63 Oct 8th, 2015 05:56 PM
mini cooper 2002 cylinder head gasket monkeybiker Maintenance & MINI Care 6 Apr 10th, 2013 10:54 AM
Its the Head gasket :( Pepperami Maintenance & MINI Care 11 Nov 21st, 2012 05:13 PM
Sump Gasket Oil Leak Maggy Mouse Second Generation MINI One 0 Sep 7th, 2012 05:12 AM
