low engine oil issue? - MINI Cooper Forum
post #1 of 2 (permalink) Old May 3rd, 2014, 05:33 PM Thread Starter
Local Time: 09:01 AM
Quoted: 11 Post(s)
When engine oil is low (about 1/4 above lowest level) and one gives the mini a hard drive, is it possible for oil to be blown out of the pcv hose (one on the left)?
genik is offline
post #2 of 2 (permalink) Old May 3rd, 2014, 11:46 PM
heathwebbo's Avatar
The oil should not be blown out of anywhere on the engine unless you have split/ill fitting hoses or its massively overfilled or pressurised for some reason.
Have you checked for splits in the hose ? If its ok you need to look at reasons for excessive crankcase pressure ( I have read other questions you have asked about oil being sprayed out onto the engine) it may be just a simple breather problem but I think you need to get it checked by a garage
heathwebbo is offline
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 09:09 PM
Ran my Mini out of oil and now I have engine noise. Timbo66 First Generation Faults & Fixes 12 Apr 17th, 2015 09:48 PM
will forging engine parts fix oil consuming issue? genik Second Generation MINI Tuning 6 Sep 25th, 2014 12:59 PM
Engine Knocking Low Oil? Help.. Any good garages around Bridgend? tashas-mini First Generation Faults & Fixes 3 May 20th, 2013 08:35 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
