how large tires can i fit on the stock alloys? - MINI Cooper Forum
post #1 of 13 (permalink) Old May 11th, 2014, 05:14 PM Thread Starter
Local Time: 11:23 PM
Quoted: 11 Post(s)
What is the largest/widest tires the stock R56S 2008 17" wheel alloys can take up to?
genik is offline
post #2 of 13 (permalink) Old May 11th, 2014, 05:29 PM
Caveman's Avatar
Local Time: 01:23 AM
Quoted: 83 Post(s)
215/45-17 or 215/40-17 depending on suspension set-up.
Caveman is offline
post #3 of 13 (permalink) Old May 11th, 2014, 09:27 PM
As above but also depends on what you final goal is
do you just want more grip or just for looks ?
marque is offline
post #4 of 13 (permalink) Old May 11th, 2014, 09:40 PM Thread Starter
Quoted: 11 Post(s)
Mainly its the looks, chicks love the looks (i sounded like batman )
genik is offline
post #5 of 13 (permalink) Old May 11th, 2014, 10:00 PM
Hi ya
Well something to take In to consideration then if it's for looks is.
A 215/45/17 tire is about 10mm bigger in dia to a 205/45/17, and a 215/40/17 will be around 10mm smaller than the 205/45/17.
This will mess with your speed reading but that's not to much of a problem as long as you know what way it has effected it so you can compensate
also if you put a 215/40/17 tire on because it is a smaller diameter than the 205/45/17 it will make your wheel gap bigger between your arch trim and tire and visa versa withe the 215/45/17
Plug the sizes in to this link and you will see what the differences are between tire profiles etc
Tire Size Calculator - Tire & Wheel Plus Sizing
If your going to lower or have lowered your car the 40 profile may be better
If not think about what you want or you will end up will big wheel gap or silly size side walls
Hope this helps
marque is offline
post #6 of 13 (permalink) Old May 11th, 2014, 10:49 PM Thread Starter
Quoted: 11 Post(s)
Ok, any clue on what kind of tire specs the mini challenge cars have?
genik is offline
post #7 of 13 (permalink) Old May 11th, 2014, 10:59 PM
Hi ya
They run a control slick tire 15" coopers or 17" cooper s jcw section 5 subsection 13
http://www.minichallenge.co.uk/pdf/2...%20-%20Web.pdf
These will not be a road tire a slick tire is a different kettle of fish
marque is offline
post #8 of 13 (permalink) Old May 11th, 2014, 11:24 PM Thread Starter
Quoted: 11 Post(s)
Originally Posted by marque View Post
Hi ya
Apart from the fact that they are slick tyres they are perfect for the looks! Is it certain that there aren't any similar specs road tyres?
What specs do they have as far as sidewalls are concerned?
genik is offline
post #9 of 13 (permalink) Old May 12th, 2014, 09:57 AM
Local Time: 12:23 AM
Quoted: 53 Post(s)
Painting your car pink too will get lots of chick looks I guarantee it.
The Nun is offline
post #10 of 13 (permalink) Old May 12th, 2014, 10:08 AM
Must be some weird "chicks" who get turned by what type of tyre you have fitted.
Big_Nige is offline
post #11 of 13 (permalink) Old May 12th, 2014, 01:26 PM
Quoted: 53 Post(s)
Oh I dont know, some women like a men with a spare tyre more to hold on too
The Nun is offline
post #12 of 13 (permalink) Old May 12th, 2014, 02:09 PM
Better for grip when wet apparently.
Big_Nige is offline
post #13 of 13 (permalink) Old May 12th, 2014, 09:30 PM Thread Starter
Quoted: 11 Post(s)
Lets stay on topic now
genik is offline
R56 GP replica alloys? Source & fit davethehearse Wheels, Tyres & Brakes 3 Oct 14th, 2013 12:41 PM
