compression test results - MINI Cooper Forum
post #1 of 2 (permalink) Old May 19th, 2014, 06:46 AM Thread Starter
Local Time: 01:57 PM
Quoted: 11 Post(s)
What should be the default/optimum compression test results for the R56S with the N14engine?
genik is offline
post #2 of 2 (permalink) Old May 19th, 2014, 11:57 AM
Hi
The problem is every engine is different I would say you you should be looking around the 180 psi mark.
The main thing is variation between cylinders you don't really want more more than 10 to 15 psi difference .
The problem is with a compression check is it is vague and sometime not that accurate and if the compression is low is it the valves intake or exhaust or rings.
I would say get a leak down test instead of a compression check at least that way if the leakage rate is high it's quick and easy to track down
Hope this helps
marque is offline
No compression on all four cylinders bane Second Generation Faults & Fixes 3 Mar 25th, 2014 04:05 PM
