coolant - MINI Cooper Forum
post #1 of 6 (permalink) Old May 24th, 2014, 12:33 PM Thread Starter
Local Time: 06:49 PM
coolant
Need help with coolant, water temperature getting up to 105/108 c, the fan is kicking in but the radiator and bottom hose staying cold. I thought thermostat so changed the housing, still the same, why would a fan start when nothin to cool. 2007 R56.
r46jackhd is offline
post #2 of 6 (permalink) Old May 24th, 2014, 01:12 PM
Quoted: 53 Post(s)
A very good very efficient radiator will be hot at the top and cool at the bottom, it shows its taking away the heat properly?
The Nun is offline
post #3 of 6 (permalink) Old May 24th, 2014, 10:48 PM Thread Starter
Had a finding today. Took for 5 mile drive, pull in drive, temp at 107c, checked bottom hose, cold, shut engine off and electric pump kicked in and after only a few moments the radiator and bottom hose start to warm up and then get hot. So coolant is moving around the system but not until engine shut down.
post #4 of 6 (permalink) Old May 24th, 2014, 11:11 PM
heathwebbo's Avatar
Local Time: 05:49 PM
If your thermostat is ok you either have an airlock or your waterpump is shot or fanbelt slipping badly.
Driving normally your engine temp should sit around 90 to 95 but will rise in queuing traffic etc, if its reaching 105 whilst driving along you have a problem also if its reaching 105 & the radiator is cold then the coolant isnt circulating. You haven't got an electric pump the noise you are hearing is the fan
heathwebbo is offline
post #5 of 6 (permalink) Old May 25th, 2014, 02:40 PM
noob
Local Time: 10:49 AM
If you changed the thermostat (and not just the housing), then the only thing left is the water pump.
pokeyjoe is offline
post #6 of 6 (permalink) Old Jun 2nd, 2014, 07:11 PM
Quoted: 1 Post(s)
Scotland
Hi jackhd, i have read though your problem and I am a mini mechanic in the main dealer, I would recommend clearing the fault memory in the car, if a fault is stored for the map-thermostat it will go into a safe code making the fan to run a lot. Clear fault memory and re-test, let me know how you get on.
Minitech93 is offline
Engine Coolant Joeytain Maintenance & MINI Care 5 May 16th, 2014 06:02 PM
Coolant estewbert Welcome New Members 4 Feb 15th, 2014 09:08 AM
Losing coolant rapidly sessy1989 First Generation Faults & Fixes 2 Nov 20th, 2013 10:19 AM
Oil in coolant gibzy First Generation MINI Cooper 2 Feb 12th, 2013 11:34 PM
Which coolant colour - please help! VFoster First Generation MINI Cooper 6 Oct 1st, 2012 10:21 PM
