default psi readings - MINI Cooper Forum
post #1 of 7 (permalink) Old May 26th, 2014, 06:03 PM Thread Starter
Local Time: 04:20 AM
Quoted: 11 Post(s)
What would be the default psi readings of a compression test for a 2008 R56S? Does BMW documentate the default readings somewhere in the manual?
genik is offline
post #2 of 7 (permalink) Old May 26th, 2014, 06:46 PM
Hi ya
Most people do a leak down check it's a much better way of finding faults and more accurate.
But if your doing a comp test you should be reading around 180psi roughly on a comp test. But the most important thing is the discrepancy between cylinders you don't want more than a 10-15 psi difference between cylinders.
marque is offline
post #3 of 7 (permalink) Old May 26th, 2014, 08:43 PM Thread Starter
Quoted: 11 Post(s)
on my car i got a 160psi reading in all cylinders
genik is offline
post #4 of 7 (permalink) Old May 26th, 2014, 09:28 PM
Hi ya
Seems a little low But as long as there all the same it's not to bad, and if you did not have the throttle wide open it will effect the out come, so 160 may not be to bad. if your worried do a leak down check on it.
So many things affect compression and all engines vary slightly.
Also stick a can of bg109 in it before you do an oil change. And check for carboning of your inlets valves
marque is offline
post #5 of 7 (permalink) Old May 26th, 2014, 10:06 PM Thread Starter
Quoted: 11 Post(s)
Please rephrase and elaborate in depth if possible, i didnt get it.
genik is offline
post #6 of 7 (permalink) Old May 27th, 2014, 11:18 AM
Ok so bg109 if you search the net you will see it is an additive you can add to your oil, you can put it before you do an oil change or half way throw a service cycle. It is designed to last one heat cycle then turn inert. but Personally i do it before the oil change. I don't see the point of putting something in to help clean out the oil system then not flushing all the crap out.
The bg109 removes and cleans the oil system and removes sludge and contaminates in your oil system, but the reason why I recommended it to you to use it for your application it also removes varnish, carbon build up and sludge from the piston rings allowing them to work as they were designed. Which would also help if your rings were starting or causing the low compression problem. Remember prevention is better than the cure. But don't think you can put in a can and you will have 200psi comp reading does not work like that.
In an engine carbon is and always has been the enemy. carbon is abrasive so in very basic terms, you are turning a lubricant ( your engine oil) in to a fine grinding paste which will cause wear which then over time kills your engine. This carbon turns to sludge over heat cycles causing all kinds of problems.
I always change oil every 6000 miles and use a bg service pack containing bg44k, bg109, bgMOA.
I hope this is In depth enough with out getting it to oil technology and metallurgy.
With ref to the intake valve, carboning of the valves it is a know problem with the r56 i have seen these valves so carboned up they have caused compression problems
This is why I mentioned about the inlet valves
Ps did you do you comp check with engine hot or cold
Hope this helps
marque is offline
post #7 of 7 (permalink) Old May 27th, 2014, 08:05 PM Thread Starter
Quoted: 11 Post(s)
I did have a comp check with engine mid (not too hot, not cold) it showed 160 in all cylinders,
genik is offline
