Daylight running lights - MINI Cooper Forum
post #1 of 2 (permalink) Old Jun 15th, 2014, 12:56 PM Thread Starter
Local Time: 12:17 AM
England
As I don't like having the headlights on (position 3 on the stalk), I've fitted some LED DRLs which adhere to the outer rim of the headlights and are wired into an ignition controlled circuit. The hardest part was trying to find a way into the cabin on the fuse box side-not easy!
The kit came from Halfords-cost 48 + wire/fuse and tape in stock.
The only problem is the fact that the LEDs stay on at night when the headlights are on but I'm hoping this won't cause an MOTfailure in two year's time otherwise I'll have to fit a cut-off switch.
David T-H is offline
post #2 of 2 (permalink) Old Jun 15th, 2014, 01:43 PM
Quoted: 53 Post(s)
If you look at the DRLs fitted to the new cars they dim when the headlights are on and also on that side when you indicate as well in normal daylight conditions.
I wondered too if they dont dim or go off when the normal lights are on whether they will say anything at the MOT, I fear they might??
The Nun is offline
2014 Mini - Daytime Running Lights LostLewis Welcome New Members 2 Jun 13th, 2014 06:21 AM
R57 2010 model. Daytime Running Lights? miniluke General Discussion 4 Jun 5th, 2014 03:20 PM
Automatic headlights and daytime running lights GimpyNuNu Second Generation MINI Exterior 8 Jun 4th, 2014 04:48 AM
Daylight Running Lights jackski2 General Discussion 3 Apr 30th, 2014 09:22 PM
F56 (2014) Mini - Daytime Running Lights Gazparc General Discussion 3 Dec 14th, 2013 09:46 AM
