thermostat housing leak - MINI Cooper Forum
post #1 of 3 (permalink) Old Jun 16th, 2014, 07:45 PM Thread Starter
Local Time: 11:22 PM
Hi guys
My 2007 mini Cooper s has been leaking coolant. I out in some k seal to stop the leak but it didn't work. The engine started smoking a little so uncalled the AA out to see it. He said the thermostat housing has leaked and don't drive it as it can cause more damage! He saidbibmay have already caused damage!
How much will it cost mentobhet a new housing?
Nikki
njsupplies is offline
post #2 of 3 (permalink) Old Jun 16th, 2014, 07:46 PM Thread Starter
Sorry, how much will it cost for a new housing? And how much damage could ibhave caused?!?!?
post #3 of 3 (permalink) Old Jun 26th, 2014, 09:56 AM
I had the exact same problem a couple of months back, I bought a new thermostat housing from GSF for 70.
Easy to replace but time consuming with removing all the hoses. When it came to it, it was actually my temperature sensor o-ring that had failed which is attached to the housing, but I was more than happy to replace the whole part. Unfortunately your unable to buy the gasket for the housing as this is where it would be leaking from.
jdizzel is offline
Replacing Thermostat Housing - Wiring Help PHNTOM77 Second Generation MINI Cooper S 3 May 29th, 2016 12:33 AM
replace thermostat and housing or just thermostat wrx fifer First Generation MINI Cooper S 7 May 26th, 2014 06:33 PM
oil leak from oil filter housing kelv1962 General Discussion 1 Jan 7th, 2014 10:14 AM
Mini one thermostat problem URGENT Jojo-2012 Maintenance & MINI Care 4 Feb 1st, 2013 11:44 PM
Thermostat Housing Replacement - 08 JCW Neil B Scot General Discussion 0 Dec 31st, 2012 06:57 PM
