Sport button on 2012 Roadster S - MINI Cooper Forum
post #1 of 8 (permalink) Old Jun 27th, 2014, 11:06 AM Thread Starter
Local Time: 05:06 PM
England
Should there be a noticeable difference in performance when during acceleration the sport button is activated?
The green light comes on but I'm wondering if the circuit has a fuse?
I assume a message triggers a response from the ECU but I can't trace the circuit from the Haynes manual.
David T-H is offline
post #2 of 8 (permalink) Old Jul 1st, 2014, 09:19 AM
Guitarmaker
Local Time: 04:06 PM
Just quicker throttle response
I believe the only difference (apart from unnecessarily heavier steering) is throttle response.
Certainly I can't feel any more power in mine.
Guitarmaker is offline
post #3 of 8 (permalink) Old Jul 1st, 2014, 09:44 AM
BlueBeastie's Avatar
Local Time: 06:06 PM
South Africa Male
Exhaust will also be pop nicely.
BlueBeastie is offline
post #4 of 8 (permalink) Old Jul 2nd, 2014, 12:09 AM
bmwr606
Local Time: 11:06 AM
Quoted: 2 Post(s)
the sport button does not make extra power nor does it change the suspension settings
it stiffens the steering by reducing power assist, changes the throttle pedal to throttle body relationship to give more throttle plate movement from less throttle pedal movement, turns on the pop and burble (not on all models/years) and if you have an automatic, changes the shift patterns both for up and downshifts
2012 CM S All4 (03/12) | Abs Black w/White Roof/Mirrors/18" White Wheels | Cold Pkg | Sport Pkg | Xenon w/ Black Housings| Manual | Sport Susp| Anth Headliner | Flat Load Floor | Bluetooth | 2 Part Center Rail | Milltek downpipe back exhaust
bmwr606 is offline
post #5 of 8 (permalink) Old Jul 2nd, 2014, 08:24 AM
Quoted: 53 Post(s)
Pressing the SPORT button, its a manual shift, does cause a noticeable small jolt as if its going into kick down, only small but noticeable so it obviously does do something to boost the performance.
Then once engaged it does feel sportier and acceleration is definitely better at the lower revs.
So whether you are supposed to feel anything I dont know, but I can in mine.
The Nun is offline
post #6 of 8 (permalink) Old Jul 2nd, 2014, 06:05 PM
rich345's Avatar
Garage
I believe the small jolt is a result of the more immediate throttle response and is not an indication of more power.
rich345 is offline
post #7 of 8 (permalink) Old Jul 2nd, 2014, 06:29 PM
Quoted: 39 Post(s)
Yes, in a manual car all that happens is that for 50% accelerator pedal movement, you get 75% (or whatever - more than 50%) throttle opening with the sport button pressed.
So it makes the car seem 'sportier' if you drive gently. If you use full throttle by (shock, horror) pressing the accelerator pedal all the way down, the sport button doesn't do anything. But lots of drivers never, ever use either full throttle or full revs, so they are impressed by how 'sporty' the button makes the car feel. It ought to be called the 'little old lady' button.....
Angib is offline
post #8 of 8 (permalink) Old Jul 3rd, 2014, 02:56 AM
Quoted: 1 Post(s)
Australia
I seem to remember seeing a Top Gear some time ago where The Stig did a lap in a car with the sports button activated and another lap with it de-activated - the lap time was almost exactly the same!!
It all comes down to how far you press the pedal on the right!!
2009 R56 Mini Cooper S: Chili Red, Black Roof, Black Wheels, ASC+T, SatNav, Very Cute!
SteveAus is offline
The Sport Button on the SD Countryman Bubu91 MINI Countryman 9 Apr 18th, 2014 10:54 PM
2007 S w/ dealer fit JCW, sport button won't turn off? FlashBastd Second Generation MINI Cooper S 3 Apr 23rd, 2013 12:49 AM
2006 Mini Cooper Sport Button rphox2003 First Generation Interior & Ice 1 Feb 28th, 2013 10:19 PM
