Boost PSI? - MINI Cooper Forum
post #1 of 1 (permalink) Old Jul 3rd, 2014, 01:46 PM Thread Starter
Local Time: 06:54 PM
Boost PSI?
Hi,
After recently resolving an issue with no boost, I hooked up DashCommand via an OBD Wifi transmitter to see what the reading on the car were after the fix. The software is showing me max boost of 16PSI and max HP of 204.
Is this correct, the readings seem high to me especially as the boost psi is supposed to be around 11.5 max?
I have an 08 cooper S that has had no mods
yaw631 is offline
R56 no boost das882 Second Generation MINI Cooper S 2 Jan 7th, 2016 07:09 AM
Boost PSI? yaw631 Second Generation Faults & Fixes 1 Jul 7th, 2014 06:27 AM
Read here if speccing visual boost radio (Saves you money!) ryanm8655 Third Generation MINI Cooper S 2 Jun 7th, 2014 12:31 PM
R56 Cooper S fault codes/ no boost das882 Welcome New Members 3 Mar 27th, 2013 09:45 AM
