Excessive AC Condensate - MINI Cooper Forum
post #1 of 4 (permalink) Old Jul 17th, 2014, 10:11 PM Thread Starter
Local Time: 11:04 AM
Hi
2010 Cooper S with 19k. on the clock.
I'm aware that using the air-con produces condensate which can be seen dripping on the driveway but I've recently noticed that there is now quite a big patch on the driveway which seems excessive.
Is this usual or should it just be the odd drop. And if it is just condensate is it usual for it to be oily, as in it staining the brick paver drive?
Thanks for any comments.
ChrisF is offline
post #2 of 4 (permalink) Old Jul 17th, 2014, 10:30 PM
Hi ya
The amount of condensation will depend on what the weather is like, more humid or wet weather it will produce more.
It is also advised that you also use the a/c in the winter some times, as it removes moister from with in the car, this also helps it from steaming up.
It's only water taste it if it's sweet it's coolant, no taste it's water.
If it's very oily it could be oil you need to check your brake fluid, engine oil levels and around your gear box for leaks.
It is possible for you washer screen reservoir to be leaking to
Hope this helps
marque is offline
post #3 of 4 (permalink) Old Jul 18th, 2014, 10:07 AM
Quoted: 40 Post(s)
Originally Posted by marque View Post
It's only water but if you are un shore taste it if it's sweet it coolant no taste it's water.
And if it gets you drunk, it's neither coolant nor water, eh?
Angib is offline
post #4 of 4 (permalink) Old Jul 18th, 2014, 10:12 AM Thread Starter
Thanks for the replies.
I don't think it is oil, though I will check, as it is practically colourless.
If it is condensate and therefore basically water, I'm still wondering why it doesn't just evaporate off the drive and leave no residue?
Thanks, Chris
ChrisF is offline
Catch tank, excessive water fillup trono Second Generation Faults & Fixes 2 Dec 19th, 2012 05:32 PM
Excessive Tyre Wear Jim_999 Wheels, Tyres & Brakes 3 Dec 6th, 2012 06:55 PM
