Battery...IBS...ground? - MINI Cooper Forum
post #1 of 2 (permalink) Old Aug 3rd, 2014, 01:19 AM Thread Starter
Local Time: 09:24 PM
Have a used 2010 S I purchased in January. Car now has 56,000 miles. US model. I think it has every option minus stripes and satellite radio. It does have the navigation system.
Starting to have a electrical issue. I thought I would check here before proceeding. I suspect I have a battery that is on its last legs..
Car starts no problem. No hint of a failing battery.
Car does have the original battery. It does have a dark eye.
Car does have the IBS ground cable sensor.
So...here is what the car is doing...
Have gotten the 'increased battery discharge' message a couple of times.
Navigation system seems to be slow to boot up.
HVAC system will often go thru a door cycle at start up.
A couple of times the max speed HVAC blower reduces one speed down.
The navigation unit will shut down about 2 minutes after engine shut down. Used to be 7-8 minutes after shut down.
As mentioned..I suspect the original battery is showing it's age. That said...I thought I would check here in case there is a body ground or maybe the IBS is going bad before replacing the battery.
Anybody seen this? I would hate to buy a $150 battery and find out there is a common engine ground kind of issue..
LoganDiagnostic is offline
post #2 of 2 (permalink) Old Aug 5th, 2014, 06:45 PM Thread Starter
Update....a new battery cured all issues. Even seems to have fixed a random car alarm issue if the car was parked and sunroof was left in the vent position.
Battery of choice came from NAPA. Model 7548. Even came with a small kit for the battery vent system. $127.
Did not reprogram the IBS. Car seems fine.
Car always started no problem with the old battery...just the secondary electronics were getting goofy.
AGM Battery markslater Second Generation Faults & Fixes 18 Oct 27th, 2016 12:38 AM
R55/R56 Key Fob rechargeable battery FIX Vanon Second Generation Faults & Fixes 8 Aug 1st, 2015 05:05 PM
Battery drain problem hoggy1972 First Generation MINI Cooper 5 Feb 5th, 2014 03:25 PM
Power steering not working & Battery light on (This is a strange one!) Plungerrr First Generation Faults & Fixes 1 Dec 27th, 2013 07:22 PM
Battery Advice Oldpaint Maintenance & MINI Care 2 Aug 30th, 2013 10:22 AM
