Sorry if this has been covered before but from all i have read i'm really confused.
i have a 2010 cooper S. From that i think i have the N14 engine 174 bhp?,
However i read that the N14 doesn't have the sport button "pops and bangs" and mine does.
I want to order some air induction parts but i cant find where the engine code is on the car to check which one i have
ahh i see, my speedo broke 2 days after buying the car and the one they replaced it with is slightly darker the half tank mark has a black surround round it too. i'm assuming they replaced with an LCI version
personally i don't see the point, from what read the changes are minimal and not worth the cost. unless you can source a decent engine cheap and fit it yourself of course. think its a straight swap but maybe wrong
He doesnt mean backfiring, well he might if the cars timing is out, but it means the crackle type noise you get from the exhaust on over run/deceleration when you lift your foot off the throttle, some people like to hear it.
The old Morris Minors used to give a fart, remember those? well its kind of a similar principle.
The n14 is installed on minis up to 2010. The n18 is 2011 and up. You may not swap the engines because the n14 dme does not have the same n18 dme engine plugs/wiring. If you change the dme, you have to sync it with your CAS or replace all of modules (DME,CAS,Keyfob) from the SAME car. Also, you wanna make sure the options are the same. Lastly, make sure that the new modules dont have any codes specially the ABS/DSC.
I'm considering buying a cooper with a seized motor, the vin indicates it's a 2007, R56 with a N14 motor. However, it also says the output is 128hp....so I'm confused. The sales ad says it's the turbo. It has the hood scoop, I haven't been to look at it yet but at $1500 it seems a steal.
As far as a replacement motor is concerned, i'm seeing wildly ranging prices from $800 to $3500. What am I missing here....will the $800 motor simply not fit without extensive modification, changing other parts etc ?
I'm just looking to swap the motor, not get into making a different motor fit.
Last 7 of VIN are TT81570 - details can be checked at the bimmerwork vin checker
Hey guys sorry to rez an older thread and im a total mini newb here but i got a 2010 cooper s with a build date of 4/10 which from what i read is right on the cusp on n14 and n18. How do i check or how CAN i check to see what i have??
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
