No power steering, wipers on, speedometer - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI Cooper > Second Generation MINI Cooper
Second Generation MINI Cooper MINI Cooper Late 2006 - Present
Old Jan 19th, 2013, 05:05 PM
Local Time: 01:10 AM
Good afternoon guys,
Hoping for some advice. My mother has a 2007 BMW mini copper and it has developed a intermittent fault recently.
Sometimes when you start the car it start up ok but the power steering has stopped working, the wipers are on and you can't turn them off, the speedometer is reading fully clockwise, the rev counter is the same and also the fuel gauge.
If you leave the car for 10 mins or so it will start up and be fine, or sometimes you can start it 10 mins later at it will be the same. Leave it for a while and it will be back to normal.
I checked all the ECU/fuse connections for water ingress but it all looked fine. We have snow at the moment and it is very wet so thought it could be that.
When the fault is present, the powers steering, engine management light is on.
Also the engine sounds like it is labouring when it does this, and once it's back to normal it sounds ok!
If its is electrical, how would that stop the power steering from working? Any ideas would be much appreciated.
Paul
Old Jan 21st, 2013, 09:21 PM
Any help on this guys?
Old Jan 21st, 2013, 09:55 PM
mab01uk's Avatar
Local Time: 02:10 AM
Paul
The power steering on 2nd Gen/Mk2 Mini's is fully electric assisted with no conventional ps pump, unlike the 1st Gen/Mk1 Mini which still has a hydraulic pump with fluid but driven by an electric motor.
Electrical problems can therefore stop both types of power steering systems working. On cars where the hydraulic ps pump is driven by a belt off the engine, then electrical failures would have no effect as long as the engine is running.
Old Jan 22nd, 2013, 09:55 PM
Ah thanks for confirming that mate. I did suspect that when I happened but wasn't 100% sure.
Any ideas on where water would get into the electrics?
Paul
Old Jan 22nd, 2013, 10:40 PM
mab01uk's Avatar
On the Gen 1 Mini it is often down to the BC1 (Body Control Module) see details in link below. However I have not heard much about a similar problem on Gen 2 Mini's and I am personally not so familiar with them as yet in order to advise you.
The BC1 (Body Control Unit) - Forums
Old Jan 22nd, 2013, 10:52 PM
Massive help thanks.
