Advice 2007 Mini Cooper - MINI Cooper Forum
Second Generation MINI Cooper MINI Cooper Late 2006 - Present
post #1 of 3 (permalink) Old Apr 26th, 2014, 10:58 AM Thread Starter
Local Time: 06:10 AM
Hi all,
My mum currently has a 03 mini which she loves but is looking at buying a newer one.
I'm taking her to look at a 2007 convertible tomorrow it's done 42k and looks and sounds to be in decent cond.
Is there anything I should look out for or check that's been done? Or anything big what's going to need replacing around this mileage?
Thanks all
lewig is offline
post #2 of 3 (permalink) Old Apr 26th, 2014, 03:48 PM
Local Time: 05:10 AM
Hi ya
I think the 2007 is still an R52 so all the normal stuff r52 and r53
Make shore the top goes up and down smoothly and properly
Rh top engine mount
Full service history and bills
Engine oil leaks
Tires and wheels are correct
All the electrics work ok just spend your time on them
Windows all work and doors lock ok
Both key fobs work ie unlock lock windows down roof down
Stereo works if its HK and sat nav
No warning lights are on during the test drive but all come on when you first tun the car on and start it.
Check the oil for colour and coolant is full and is coloured power steering fluid is clean and correct level
Gearbox is smooth and no noises when you have the clutch up or down
Exhaust is in good condition ( back box )
All the panel shut lines are good and match well
Dents chips faded or orange peel paint etc
Condition of the trip inside and out
Turn the steering full left full right listen to the power steering pump for abnormal noises
And the list goes on
Take a note book it's always good to write it down its a good bargaining point and a list if they fix things
If you are un shore the AA and a like do a vehicle inspection service and HPI check
If it' a later r57 pretty much as above as well
Good luck take your time if in doubt take pics and ask someone will help
marque is offline
post #3 of 3 (permalink) Old Jun 24th, 2014, 05:51 PM
(And the list goes on )
Personally i'd go for the diesel models unless you want a cooper S...the diesels are more fun,faster,smoother,cheaper to run and suffer a lot less engine problems also it would be worth getting one from a dealer thats still under warranty if your budget can stretch that far.........
pawea is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 01:33 PM
Mini Cooper 2007 1.6 AIR Con - Am I stupid ? marksinnott General Discussion 3 May 9th, 2014 12:00 AM
Would a Mini Cooper s front bumper 2012 plate fit a 2007 Mini one? irfan.s Second Generation MINI Cooper S 1 Mar 6th, 2013 11:52 PM
Newbie with a 2007 Mini Cooper and a 2010 Mini Cooper S JCW Converible dcphotos Welcome New Members 0 Sep 18th, 2012 01:05 AM
