Can anyone tell me what these warning lights are please? - MINI Cooper Forum
Second Generation MINI Cooper MINI Cooper Late 2006 - Present
post #1 of 4 (permalink) Old May 8th, 2014, 11:44 AM Thread Starter
Local Time: 04:26 PM
United-Kingdom Can anyone tell me what these warning lights are please?
Hello
I am new to this forum so please forgive me if I've not got the hang of this yet!
I recently bought a 2007 2nd generation Mini Cooper and while driving the attached lights came on and continued to stay on. Can anyone tell me what they mean please? The exclamation mark is actually red, not yellow as depicted in the picture.
Many thanks for your advice/help/suggestions.
Name:	mini lights.jpg
webbobirdie is offline
post #2 of 4 (permalink) Old May 8th, 2014, 12:23 PM
Quoted: 53 Post(s)
The 2 lower lights are tyre pressure warning system, the red vehicle lift means it needs a garages attention, the upper light is brakes and the exclamation mark I would think its an urgent prompt hey get this sorted.
Could mean brake pads low, brake fluid low, brake fluid overdue for change, tyre pressure needs checking?
Really needs plugging into a reader to get the exact code, otherwise youre guessing to a certain extent.
The Nun is offline
The Following 2 Users Say Thank You to The Nun For This Useful Post:
post #3 of 4 (permalink) Old May 8th, 2014, 03:52 PM
Local Time: 03:26 PM
Quoted: 40 Post(s)
The very top light is the brake warning light. Usually this is yellow, meaning you have the handbrake on. If it is red, it means the brake fluid level is low and needs to be topped up - drive with care as you may find the pedal moves further than expected before the brakes come on.
However.... with the service warning symbol also showing in the middle display at the same time, it may mean there is an electronic system fault - for example, if the brake fluid level sensor had been disconnected.
The bottom symbol I have always liked to think means "Don't turn round, because there are two aliens sitting in the back seat and they have probes". Sadly I have been told the reality is that it means the car thinks there are rear seat occupants without belts on, though I have never seen that message.
Angib is offline
post #4 of 4 (permalink) Old May 14th, 2014, 04:39 PM Thread Starter
Thanks very much for your replies, I took it to a Halfords Autocentre today and they said the brake pads and fluid are fine and they think it's an electrical fault which they can't fix. So taking it to another garage on Friday....
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
warning lights martinjenkins1971 First Generation Faults & Fixes 1 Mar 10th, 2014 01:40 PM
Warning lights lit again! minidriver_one First Generation MINI One D 1 Nov 23rd, 2013 04:53 PM
abs, tpms dsc warning lights on after wheel rotation lemat1 First Generation Faults & Fixes 10 Apr 27th, 2013 06:05 PM
abs, tpms dsc warning lights on after wheel rotation lemat1 First Generation Faults & Fixes 0 Apr 16th, 2013 09:31 AM
Multiple warning lights on start up Sparkling Silver Second Generation Faults & Fixes 8 Oct 19th, 2012 02:48 PM
