Engine woes new r56 cooper - MINI Cooper Forum
Second Generation MINI Cooper MINI Cooper Late 2006 - Present
post #1 of 15 (permalink) Old May 10th, 2014, 02:57 AM Thread Starter
Local Time: 05:51 PM
Sold the cooper s and bought a 2007 cooper r56 everything fine for a 30 min test drive just my feckin luck after I bought it and filled her up the idle was rough at traffic lights fine above 1000rpm and hitting speeds of 80+ np on mway for over three hours then the management light started flickering no loss of power at all tho !now the management orange light is on constantly and surprise surprise once the fuel level dropped to three bars no more idle problems......bstard light still of tho......any ideas guys......gonna get her on the computer on Monday see what she throws up any heads up would be great
pawea is offline
post #2 of 15 (permalink) Old May 10th, 2014, 05:05 PM Thread Starter
The plot thickens it would seem.....got up this morning and the car seems fine no rough idle and no management light......Good luck or something worse....
pawea is offline
post #3 of 15 (permalink) Old May 16th, 2014, 12:31 PM Thread Starter
Looks like this is gonna be a ballbreaker.....hooked it up to the computer got two errors
cyl 1 misfire detected and o2 sensor.......i replaced the coilpack on cyl 1 ...rescanned and now im getting multiple cyl misfires errors....cyl1 misfire.....cyl 3......misfire.......havent changed the o2 sensor yet could the o2 sensor cause cyl misfires ?
pawea is offline
post #4 of 15 (permalink) Old May 17th, 2014, 11:06 PM Thread Starter
No luck changed the o2 sensor today and the coils .....waste of time codes cleared then came straight back again.....this looks like the dreaded carbon buildup or a sticking valve grrrrrrr.......gonna try the seafoam treatment first......if that doesn't work looks like the heads gonna have to come off...........
pawea is offline
post #5 of 15 (permalink) Old May 18th, 2014, 06:03 PM
Local Time: 04:51 PM
Quoted: 25 Post(s)
Do a compression or if you can a leakdown test to se if that shows any problems
drozd is offline
post #6 of 15 (permalink) Old May 19th, 2014, 12:47 AM Thread Starter
thx for the reply man aye i'm gonna do a compression test tommoro.....seafoam was a waste of time tried it today.....and i also found out the carbon issue only applies to the S anyway so another 20 wasted.......you cant win with these problems either you go to a dealer and get fleeced often with the problem still not diagnosed correctly or you do it yourself and waste money changing stuff hoping for the best....ahhhhh the joys of motoring....crazy thing is the car runs like a wee gem above 1000rpm loads of power and smooth as silk....just can't understand what could be the issue surely a damaged head or valve would be apparent at high revs also.........from what i've read online so far these N12 pug engines are chocolate teapots....with a whole host of issues even with low mileage examples ...simply not fit for purpose.....a shame for BMW......just hoping its not gonna be a lemon...our cooper D with way more mileage runs like a dream
pawea is offline
post #7 of 15 (permalink) Old May 19th, 2014, 01:18 AM Thread Starter
Wondering could this be a faulty MAP sensor ? would explain the poor/lumpy idle does the MAP sensor throw up any codes if its bad ?
pawea is offline
post #8 of 15 (permalink) Old May 19th, 2014, 04:33 PM Thread Starter
UPDATE
checked the plugs today all look nice and clean a nice tan colour with no pitting
i removed the lambda sensors both.... and cleaned them
i topped up the engine oil as level was lowish
i sealed the flange between the cold air intake and the airfilter housing which was loose
i also ran a can of Cataclean through it incase the seafoam had clogged up the cat
i cleared the codes and touch wood she seems fine gona take her for a thrashing now hope this has sorted the issue....seems all to easy tho....nothins ever that handy....
pawea is offline
post #9 of 15 (permalink) Old May 19th, 2014, 07:42 PM Thread Starter
No luck bad idle again this time codes are
P0030 HEATER CONTROL CIRCUIT BANK 1 SENSOR 1
AND
P0301 CYLINDER 1 MISFIRE DETECTED
i also noticed an OL fault in the fuel system any one know what this is ?
can any body see any other errors on these diagnostics ?
pawea is offline
post #10 of 15 (permalink) Old May 20th, 2014, 06:02 PM Thread Starter
Thx man for the reply i've ordered a new crank sensor just in case today i replaced the pre cat 02 sensor for a 140000 mile one from a breakers thankfully the 02 sensor errors are gone and the open loop fuel fault now just that damm misfire
im getting two codes and misfires across multiple cylinders now same codes ive ruled out plugs and coils as plugs look new nice tan deposits and no pitting
coils are all new also
pawea is offline
post #11 of 15 (permalink) Old May 21st, 2014, 05:05 PM Thread Starter
to date
NEW BERU OE PLUGS
NEW COILS
REPLACED BOTH 02 SENSORS
SEAMFOAM TREATMENT
CATACLEAN TREATMENT
INJECTOR CLEANER DIRECT TO THE INLET MANIFOLD/FUEL ADDITIVE
CHECKED FOR VACCUME LEAKS
CHECKED INJECTOR WIRING
CHECKED OIL LEVEL
CHECKED VAVLE COVER FOR CRACKS/LEAKS
RESET ECU
COMPRESSION TESTED
CYL 1-173
CYL 2-174
CYL 3-172
CYL 4-173
I'm fresh outa ideas man
maybe crank/cam sensor but surely that would thro up a separate code directly related to the component that is failing ?
I'm in way over my head now looks like a replacement engine is the way forward by the time i replace everything releated to this misfire i'll have spent near the same money....madness
pawea is offline
post #12 of 15 (permalink) Old May 21st, 2014, 06:55 PM Thread Starter
UPDATE
looks like the bstard cyl 1 piston ring is failing....after doing a compression test this morning all came back fine however after removing the plugs again today to check the gap no 1 cylinder plug is full of oil on the tip- engine side nightmare at least now i know why its misfring....solutions,fixes anyone ?
pawea is offline
post #13 of 15 (permalink) Old Jun 24th, 2014, 05:08 PM Thread Starter
Another update folks i'm getting closer now.......changed both camshaft position sensors today and the car instantly began running better although still off a cylinder,this cant be right i thought so to my horror one of the new coils i installed weeks ago was breaking down every now and then,i put another coil in to check and the car instantly came to life......moral of the story don't assume new parts are faultless.......now the car idles fine and the misfire is gone as is the check light.....well not quite when i pull up to traffic lights sometimes the revs struggle to stay at idle moving between 500rpm and 950 rpm with the check light flashing then going out.....similar to the original issue i had although not as severe,this has gotta be a software issue with the ecu/dme i cannot think of any hardware problem that would cause this also there are no stored or pending codes being picked up either thank goodness.....it has improved like 90% over the previous state however i'd still like to have it running 100%.........thx for all the replys folk any others with similar problems post away if you think it may help
pawea is offline
post #14 of 15 (permalink) Old Jun 30th, 2014, 12:12 PM
MINI Technician Sydney
Quoted: 1 Post(s)
Australia Male
are there any other engine control unit faults other than the cylinder misfire faults?
I've seen r56 thermostat cause a lot of problems when they go bad.
Trying bringing up a live coolant temp reading and then find the coolant temp sensor in the thermostat on the left side/back of the motor. top of the thermostat it's a green plug. pull on the wiring loom lightly see if the temp reading bounces around a lot
EfficientDynamics is offline
post #15 of 15 (permalink) Old Aug 6th, 2014, 08:42 AM
Was this resolved? Be interested to hear how.
originalracingsnake is offline
R56 Cooper S - Which engine coolant? cupofjavaa Second Generation MINI Cooper S 8 Jul 11th, 2015 08:44 PM
Difference in chassis and body R50/53 → R56, Cooper → Cooper S d-b First Generation MINI Cooper 0 Apr 12th, 2014 08:44 PM
MINI R56 engine Timing chain genus9 General Discussion 7 Apr 1st, 2014 11:18 PM
True running costs of R56 Cooper S? cupofjavaa General Discussion 8 Nov 23rd, 2013 08:25 AM
R56 Cooper S engine knock when accelerating j87d Second Generation Faults & Fixes 3 Sep 2nd, 2012 01:48 AM
