| Second Generation MINI Exterior Second Generation MINI Exterior 2006 - Present |
| 1cm !, that's a big stone chip. Because of the size it's going to be impossible to sort it fully but the following ( and a bit of time / trial and error ) should at least protect it and make it look far better. Touch up pen from Mini required to fill the chip and build up level until proud of paint surface. Next using 'Langka' applied to a smooth cotton cloth wrapped tightly around a credit card, slowly rub the 'blob' until flush. Depending where the chip is and the size of it depends on the end result. 57 Plate R56 PW/B MCS |
| If you dont want touch up pen, then a respray is your only option. Same thing happened to my odl mini and every one said it needed a respray. This is because of the curvature all over the bonnet. You cant spray a small section and get it 'even' Good luck.. |
| Thanks for your tip................. will try the Langka stuff.... had a go at a what can only be described as stone scrape on the bonnet at the weekend, but i will redo it with the langka as the the amount of build up was just too much with the T Up Pen..... cheers on a similar note why do white cars ( sorry pepper white minis ) have dark grey/black primer and black cars have white primer ?? never ever understood that ![]() |
| Tags: chip, paint, stone |
| Stone Chips | crimond | Maintenance & MINI Care | 10 | Oct 11th, 2009 07:47 PM |
| 3 stone chips | AlexF2003 | First Generation Works | 34 | Jan 30th, 2007 04:53 PM |
| Stone Chips!!!!! | Paul c | General Discussion | 28 | Jul 26th, 2005 02:45 AM |
| Stone Chips | John24 | First Generation Faults & Fixes | 8 | May 7th, 2002 03:44 PM |
| Stone Chips | MINIALEX | First Generation Faults & Fixes | 4 | Mar 21st, 2002 01:39 PM |
