remove unperforated blank in scoop - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Exterior > Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
Old Sep 19th, 2007, 04:19 PM
Den W's Avatar
Now Aero Kitted!
Local Time: 08:10 PM
United Kingdom Male View Den W's Lightning Blue & Body Color 2nd Gen MINI Cooper S Profile
A bit of a long winded title! Does anyone know if the the honeycomb insert in the MCS scoop can be removed? If so how? I haven't even attempted anything yet just don't want to cause any damage to the bonnet. I've had the spot lights fitted which comes with a new grill, because my car is an early one (DEC 06) the new grill has smaller vent/holes I wouldn't mind just having an open scoop to keep things cooler (as in temp!)..Any thoughts?
cheers
Den
Old Sep 19th, 2007, 07:52 PM
red_S's Avatar
Send a message via MSN to red_S
Local Time: 09:10 PM
Slovenia Male View red_S's Chili Red & White 2nd Gen MINI Cooper S Profile
Hi!
I removed mine completely.
First you have to remove the small torx screw which is located on the under bonnet side aprox. on the middle of the scoop. Then you remove the whole scoop - from the outside. It is held in place by 4 or 6 "pins" (its a stick which has a round end and this end sits in a hole :-) ) So you should just pull it up - it is possible to slide a screwdriver or similar in between the scoop and the hood and lift the scoop on different sides - BUT be very carefull not to damage the paintwork!!
Unfortunatelly i have no pics...
i hope it helps
regards
damir
Regards,
Damir
Old Sep 19th, 2007, 09:02 PM
Scotland Male
Scotland
The new Challenge car has them all open looks as though grinded out and deflector to put all air to top of turbo
Old Oct 1st, 2007, 03:02 PM
red_S's Avatar
Do you have some photo where the "hole" is visible? And the deflector?
thanks
bye
Regards,
Damir
Old Oct 1st, 2007, 03:19 PM
Scotland Male
Scotland
Red-S this is all i have please see link
http://www.mini2.com/forum/2nd-gen-j...car-scoop.html
Old Oct 17th, 2007, 05:38 PM
red_S's Avatar
@DerekH: Thanks, it is clear enough. It seems to be be very simple piece of metal or plastik bent to direct the air to the turbo.:-)
Regards,
Damir
Something for the toggle blank in the GP mikeythemini First Generation Works 8 May 9th, 2007 04:58 PM
BBR venturi scoop, M7 Scoop air divertor speedman First Generation MINI Tuning 16 Jul 8th, 2005 08:32 AM
Blank canvas Cooperated First Generation MINI Tuning 13 Jan 12th, 2005 06:13 PM
How to remove bonnet scoop? murphymok First Generation MINI Cooper S 2 Oct 21st, 2003 12:17 PM
