| Second Generation MINI Exterior Second Generation MINI Exterior 2006 - Present |
| fitted spot lamps on my mini cooper r56 they are great fitted my self but i am a ford master tech found very easy bmw printed off instructions they also do not need coding |
| Thats handy to know, thanks richards! My previous MINI had Hella spots fitted (also no need for coding) by my uncle who is/was an auto electrician, so if the R56 one can be done yourself as well and no need for coding thats good news! Is there a 'how to' anywhere online?? |
| spot lamps on the r56 model picks up it feed from the lighting module in the footwell on the nearside behind the kick trim got a mate to print off wiring diagrams on how to wire them up from my local bmw dealer also checked with them and confirmed no need to configure and also tells you in the instructions as well. also fitted new grill to make job easier grill comes with brackets to mount spot lights so they fit in the right place note had to remove and swap over chrome parts over to new grill Last edited by richards; Dec 9th, 2007 at 08:31 PM. Reason: add more info |
| Tags: cooper d, dooper, fitting, lights, spots |
| Dealer Program spots lights | Blackaeromini | First Generation MINI Exterior | 3 | Jan 29th, 2005 03:51 PM |
| Front Spots - how many/size? | oleum | First Generation MINI Exterior | 3 | Aug 7th, 2004 08:04 PM |
| Mini Driving Lights (Spots) What is your dealer charging you for these.??? | dinger | First Generation MINI Exterior | 8 | Jun 14th, 2004 02:56 PM |
| Spots in front bumper | ButtonIt | First Generation MINI Exterior | 5 | Nov 10th, 2003 04:25 PM |
| How much for the front spots in U.S.? | rei00 | First Generation MINI Exterior | 5 | Feb 8th, 2002 12:36 PM |
