| Second Generation MINI Exterior Second Generation MINI Exterior 2006 - Present |
| Can you use main & dipped beam together My non zernons are pretty marginal , I do notice that when flashing the headlights both main and dipped beam come on and the lighting is superb Can this configuration be wired by some clever relay or some such electric magic without disaster. i have been through the bulb upgrade route but the main/dipped beam on looks great Mike |
| Er no. The point would be on main beam the dipped beam would be on also, it would revert to dipped only when dipped. So main beam better , dipped beam the same ie. non dazzley Mike |
| Fair enough , I will just stick to annoying folk with not so easy to dip front fogs... Now there's an idea can fr fogs be wired to on with main beam ( I know spots can , but it seems silly to not use the fogs) Not interested in the legality side of things ( my risk ) just fascinated how to inpove the dreadful main beam![]() Mike |
| I have found the standard main beam more than adequate - a bright and wide beam - and i do drive a lot on unlit country roads. In fact the only problem I have is other peoples' lights being too bright. |
| Tags: main dipped beam |
| Replacing Dipped/low beam bulb | Mess | First Generation MINI Exterior | 5 | May 8th, 2010 03:15 PM |
| Spotlight with main beam | robh964 | First Generation MINI Exterior | 10 | Dec 8th, 2006 05:39 AM |
| Main Beam problems | matada34 | First Generation Faults & Fixes | 3 | Feb 6th, 2006 07:45 PM |
| New light bulbs for dipped beam... | rakh1 | First Generation MINI Exterior | 3 | Jan 12th, 2006 05:24 PM |
| Dodgy main beam | Mini Cruiser | First Generation Faults & Fixes | 11 | Dec 24th, 2002 02:11 PM |
