| Second Generation MINI Exterior Second Generation MINI Exterior 2006 - Present |
![]() seems the parts dept you deal with then don't have a clue what they are supplying Front JCW Badge Part Number ends 175101, Rear JCW Badge Part Number ends 175102, they are £46.81 each + VAT , yes you do need a JCW Chassis Number but the badges can be bought separately Front & Rear ![]() BTW, while we are on the subject of JCW Parts, I have been waiting patiently for the update from you reg the R56 JCW Exhaust Trims.... needless to say I'm sure I'll be waiting another while ![]() http://www.mini2.com/forum/2nd-gen-e...aust-trim.html |
| Oh is that so Mr Sarcasm .Nun the less i got my JCW exhaust trim modified the hell out of it with no luck. the only way of getting it on is to cut the larger diameter part of you origianl exhaust end (without the trim) then it should slide on with little to no modification but when you have paid alot for a car Warranty counts so decided against it. So the answer is the R56 "S" JCW exhaust trim cannot fit the COOPER (as far as i am aware/tried) unless you go to drastic measures and cut you original exhaust. Joe |
| Tags: badge, front grille, jcw |
| Front grille badge | GTT 280 | First Generation MINI Exterior | 3 | Nov 16th, 2006 08:15 AM |
| front MC badge replace for smaller MCS badge? | tyrerc | First Generation MINI Exterior | 3 | Aug 31st, 2006 12:31 PM |
| JCW Front badge. | KMK163 | First Generation MINI Exterior | 6 | Jun 19th, 2006 11:50 PM |
| Front JCW Badge | Andyb-NW | First Generation MINI Exterior | 4 | May 14th, 2006 12:35 PM |
| Partnumber JCW front bumper badge? | Maaij | First Generation MINI Exterior | 3 | Aug 9th, 2005 09:21 PM |
