Switching to Xenons. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Exterior > Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
Old Dec 11th, 2008, 05:22 PM
wisey113's Avatar
Driver
Local Time: 08:23 PM
United Kingdom Male View wisey113's Astro Black & Body Color 2nd Gen MINI Cooper Profile View wisey113's Classified Ads
Exclamation Switching to Xenons.
Hi,
Ive got a pair of xenons in my garage and I tried to fit them to my cooper instead of the standards. I know they need parts to go with but i was wondering what parts they were? It has the little silver box that attaches underneath on it but when i plug them in only the indicators work?? Can anyone help????
cheers, Jamie
Don't blink!
Old Dec 11th, 2008, 06:02 PM
adam_Randell's Avatar
Send a message via MSN to adam_Randell
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile View adam_Randell's Classified Ads
i dont know the answer to your question. however, if you dont mind me asking, how much did they set you back?
Old Dec 11th, 2008, 06:12 PM
wisey113's Avatar
Driver
£200. But I have a very bad feeling someone's done me over because they definitely arent working and every time I try and get hold of them I don't get answer. I thought it was too good to be true!!
Don't blink!
Old Dec 11th, 2008, 06:18 PM
CC07ERS's Avatar
TYPE R GT VTEC POWERED
Local Time: 09:23 PM
Scotland Male View CC07ERS's Laser Blue & White 2nd Gen MINI Cooper S Profile View CC07ERS's Classified Ads
the car will need to be recoded , iam sure
Old Dec 11th, 2008, 06:28 PM
wisey113's Avatar
Driver
I can only guess thats expensive??
Don't blink!
Old Dec 11th, 2008, 07:04 PM
whats recorded mean?
£200 seems a very good pirce! they go for £350 each on ebay!
Old Dec 11th, 2008, 07:17 PM
R56 ones are usually cheap, due to a limited audience at present.
I think its a bit of rewire job if i'm honest. Best bet is to speak to Mikey off Newministuff. He is handy with elctrics. But i think your inputs etc will all be different on the xenons to the halogens you already have. They are most definately plug and play. But it is easy enough to rewire.
before speakign to Mike you should check you have bulbs in the Xenon bit, also make sure you have the Ballasts, these will probably be in a 3 inch by 4 inch box under the light, with a big warning sticker on it.
Legally in the uk you do need autoleveling and headlight washers to run them 100% legal, but if using OEM units you will most probably not get questioned.
Old Dec 11th, 2008, 08:37 PM
KenL's Avatar
Did they not come with the unit that generates the correct high voltage signal to spark them and keep them running?
Old Dec 11th, 2008, 10:27 PM
wisey113's Avatar
Driver
they came with that silver box that bolts on underneath and all the bulbs but they just dont work!? will take them to the dealer tomorrow and see what they say!
Don't blink!
Old Dec 12th, 2008, 09:39 AM
on ebay they are £350 each....£700 for a set!
Old Dec 12th, 2008, 05:01 PM
JHorwitz's Avatar
hold on a minute, did you buy a new headlight unit, or just the bulbs and ballasts? as in an aftermarket kit?
ITS HERE!!!!........R56 S, Sparkling Silver, Sat Nav, Redwood Red Lounge Leather, Sun Roof, web spokes, Colour coded arches click here...
Old Dec 13th, 2008, 10:11 AM
wisey113's Avatar
Driver
I bought two xenon headlights which came off a mini cooper S and they were complete. I went down to my dealer to ask why they wouldn't work and it turns out you need to buy a retrofit installation kit so I decided that I really don't want the effort, so I figured I'm just gonna resell them.
Don't blink!
Old Dec 14th, 2008, 09:19 PM
Did you get a price for the whole job? Both parts & labour I mean.
Old Dec 14th, 2008, 10:18 PM
minicabrio's Avatar
Soon to be deleted !!
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Interesting one this
If you already have the headlamp washers fitted to your MINI, the upgrade should be fairly simple, unlike the 1st gen MINIs , as all the required sensors and wiring is already in place and built into the car.
Legally to have Xenons, the car also needs the headlamp wash system to be fitted.
The BMW upgrade kit consists of just the lights, ballast packs and control unit, as you already have these, the upgrade should be simple if you have the washers, if not, they will need to be installed, which will be costly, and probably make the project a non-starter
RealOEM.COM * BMW R56 Cooper INSTALL.KIT, XENON LIGHT
  #15 (permalink)
Old Dec 15th, 2008, 11:27 AM
settling in nicely
Northern Ireland Female View thetope's Chili Red & White 2nd Gen MINI Cooper Diesel Profile
i don't see how you would have the washers if you didn't already have the xenons specced though? i heard it was a fairly major job to retro fit the xenons as much beefier wiring was needed. there's a much bigger windscreen wash reservoir as standard with the xenons specced as well, as they use a lot of water.
switching out ryanwei First Generation CVT & Automatic 4 Aug 30th, 2006 03:57 AM
2005 Xenons swappable with 2004 Xenons? TomH First Generation MINI Exterior 9 Aug 26th, 2004 10:57 AM
Headlights not switching off suziejohnes First Generation Faults & Fixes 3 May 26th, 2004 11:02 AM
Switching off DSC..When and Why? kshapiro General Discussion 16 Mar 9th, 2002 11:02 PM
