Halogen Headlights - Orange Indicator Lenses - Clear :) (DIY Guide) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Exterior > Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
LinkBack (7) Thread Tools Rate Thread
  7 links from elsewhere to this Post. Click to view. #1 (permalink)
Old Feb 9th, 2009, 02:37 PM
JpMcC's Avatar
JP :-)
Local Time: 03:12 AM
Ireland Male View JpMcC's Chili Red & White 2nd Gen MINI Cooper Profile View JpMcC's Classified Ads
If like me you didn’t spec the orange indicator lenses when buying your R56 I’m sure you have often kicked yourself, however fear not anymore.
Having read different reports from people who said it wasn’t possible and other who said it was I decided to give it a go and I thought I would post my results.
Tools Required:
- 8-10mm spanner
- t25 Torx Screwdriver
- Flat Head Screwdriver
1: Here is a pic of my R56 Cooper with the Orange Indicator lenses in the headlights ...
2: Unfortunately it is impossible to do this mod without removing the headlight from the vehicle, fear not though this is not as daunting as it may seem. The Headlights are held on with 4 bolts (marked with the circles on the Pic Below)
3: The next job is to completely remove the wiring loom from the headlight (see below)
4: Once both headlights have been removed you should be left with the following:
5: Now we need to get at the awful orange indicators, first job is to remove the rubber covering from the headlight (sorry about the poor pic quality here)
6: Now you’ll need to gain access to the orange lenses, to do this you must remove the indicator bulb and wiring module, this is held onto the headlight using 2x T25 Torx Screws (Marked with white circles on the pic)
7: Once removed you will be able to see the Indicator lenses in all its glory.
8: Now the bit we have been waiting for, to remove the orange indicator, the lense is held on with 2 clips (white circles on pic), I found it best to prise the clips out using a small flat head screwdriver, and to pop the lense out just place your thumb through the hole and push hard. The lense will fall out into the headlight.
9: To get the lenses out, just move the headlight around, there is a gap at the bottom and the orange indicator lense will just slide out.
10: The next job is to change the bulbs, you will need to get a set of bulbs which are silver in colour but flash orange, other wise you will not have the proper legal requirement for indicator lenses at the front of your car. The bulbs can be obtained from the MINI2 Sponsor New MINI Stuff.
11: Once you have all the above steps completed just do the steps in reverse and put all the items back in their proper place. Re-Connect the main wiring loom back into the headlights and replace the bolts. Once all that is completed you should be left with a fantastic new set of “clear” indicator lenses
Although this may seem quite a bit of work it took me approx 30min to complete the mod and refit the headlights and I didnt have any instructions to work from.
All of the above is guide to help others change the indicator lenses on the halogen headlight on their MINI and anyone that follows the guidelines does so at their own risk and I take no responsibility for anything which may go wrong whilst following the guidline
The Following 5 Users Say Thank You to JpMcC For This Useful Post:
Old Feb 9th, 2009, 02:49 PM
ShaunSheep's Avatar
Totally maniacal!
United Kingdom Female View ShaunSheep's Laser Blue & White 2nd Gen MINI Cooper S Profile
Brilliant 'how to' guide JP!
Think you'll make quite a few people very happy by posting this
And it makes such a difference to the look of the car - great job, looks ace!
Old Feb 9th, 2009, 02:57 PM
Troy's Avatar
Wanted a JCW!!
Local Time: 02:12 AM
United Kingdom Male View Troy's Chili Red & Body Color 2nd Gen MINI One Profile View Troy's Classified Ads
Nice job there!
You reckon this will work on the Xenon units too?
Now to find a cure for the rear lights!! Although the orange has grown on me!
It's a Mini Adventure.
Old Feb 9th, 2009, 03:00 PM
JpMcC's Avatar
JP :-)
Quote: Originally Posted by Troy (original)
Nice job there!
I am unsure about the Xenon units but I cant imagine there will be much difference.
Having taken the rear lights apart it's not possible, better to keep your eyes on ebay or I think NewMINIStuff sell the set
Old Feb 9th, 2009, 03:15 PM
Troy's Avatar
Wanted a JCW!!
I'm planning to do what Adam has done and tint the front lights, in which case it won't make a difference I wouldn't have thought.
Do the rears come out? I was thinking some red spray or vinyl, instead of white. Might look better with the rest of the light unit.
Old Feb 9th, 2009, 03:16 PM
United Kingdom Female View I love MINI, Laura's Royal Grey & Silver 1st Gen MINI Cooper S Profile View I love MINI, Laura's Classified Ads
SO MUCH BETTER! Great work there! Looks brilliant. God, hate those orange lenses!
Old Feb 9th, 2009, 03:28 PM
andrewcregan's Avatar
Andrew ATC
Scotland
Great job JP.
The car looks miles better
Old Feb 9th, 2009, 03:43 PM
nylo's Avatar
Totally Mental!
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile View nylo's Classified Ads
^^^ What she said!
Good to see you've finally done this JP, it looks sooooo much better Look forward to seeing it in the metal
Old Feb 9th, 2009, 04:03 PM
View keano619's Classified Ads
Thanks alot JP
Saved me £220 to get some new headlights fitted
Keane
Old Feb 9th, 2009, 04:24 PM
118's Avatar
118
nyahahahaha
Send a message via MSN to 118
United Kingdom Male View 118's Laser Blue & White 2nd Gen MINI Cooper S Profile View 118's Classified Ads
excellent job there looks great
Old Feb 10th, 2009, 06:31 AM
Sportspack Mark's Avatar
Send a message via MSN to Sportspack Mark
Northern Ireland Male View Sportspack Mark's Classified Ads
Looks cracker JP!
May be a help to me in a while!
Old Feb 10th, 2009, 08:08 AM
vickietots's Avatar
Totally Insane!
Send a message via MSN to vickietots Send a message via Skype™ to vickietots
United Kingdom Female View vickietots's Dark Silver & Black 1st Gen MINI Cooper S Profile
Excellent job! Looks soooooo much better! Also a great write up!
Old Feb 10th, 2009, 11:43 AM
JP do you know how much a set of new rear lights are that have the clear indicator part?
Old Feb 10th, 2009, 12:58 PM
Troy's Avatar
Wanted a JCW!!
Check on NewMINIStuff.com
I think they are around £150.
  #15 (permalink)
Old Feb 10th, 2009, 03:03 PM
JpMcC's Avatar
JP :-)
Looks cracker JP!
Ohh do I smell an R56 coming your way soon???
As troy posted Mikey sells the set of rear lights with the clear indicator lenses
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-mini-exterior/167889-halogen-headlights-orange-indicator-lenses-clear-diy-guide.html
Posted By For Type Date
Zubehör und Tuning Clubman Cooper - Seite 2 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Mar 16th, 2009 05:31 PM
Zubehör und Tuning Clubman Cooper - Seite 2 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Mar 15th, 2009 11:12 PM
MINI² - Einzelnen Beitrag anzeigen - Gelbe Blinker in Weiße verwandeln?! - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Mar 15th, 2009 06:28 PM
Geht oder geht nich? JCW Grilleinsatz auf MCD? - Seite 13 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Mar 12th, 2009 09:56 AM
MyKa.org: Forums / Ka Klassifieds / [WANTED] Clear headlights This thread Refback Mar 11th, 2009 08:39 PM
Gelbe Blinker in Weiße verwandeln?! - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Mar 11th, 2009 04:50 PM
Gelbe Blinker in Weiße verwandeln?! - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Mar 11th, 2009 04:49 PM
Halogen headlights to Xenon headlights Jon TDI First Generation MINI Exterior 16 Feb 11th, 2012 10:07 PM
Clear indicator lenses benjiboy8000 First Generation MINI Exterior 1 Dec 25th, 2008 07:57 AM
Adjusting halogen headlights baskers First Generation Faults & Fixes 3 May 17th, 2007 01:12 PM
Halogen headlights really dull? Roofas First Generation MINI Exterior 16 Jan 9th, 2006 02:54 PM
Side indicator clear lenses alicantecooper First Generation MINI Exterior 1 Dec 18th, 2003 12:08 PM
