| Second Generation MINI Exterior Second Generation MINI Exterior 2006 - Present |
| scratched my mini!!! help i let my little cousin wash my car and i wasnt watching and he has 'scrubbed' too hard to get some spots of muck off and scratched the paint! ![]() there are small scratches on the passenger door about 10cm by 6cm and the same on the bonnet. how much is this going to cost me to sort out??? most of the little scratches are just on the serface but one is through the paint (i dont want to do it myself as i dont want to get it wrong) any advice?? Lil red mini |
| As Turbs says, sounds like most of your scratches will polish out. A rough rule of thumb is; if you can't feel them with a finger nail they'll polish out. You can try this yourself with t-cut or similar compound. However, if your car is a dark colour you could end up with a dull patch. A good bodyshop will be able to paint the scratch that has gone through the lacquer, and polish the others. Wherabouts are you? |
| I would try before anything else Quixx scratch remover as T-Cut is a big no no. If you actually saw a sped up process of what that does to your paint you'de be sick. Quixx is the nuts and will deffo remove it if it cant be felt. Quixx is a chemical cutting compount so has no grit of any kind to cut the paint it just thins it instaed wich leaves no swirls and blends perfectly. The only reason its not used all over is due to its price per tube. Its about £10 but try that first then try a body shop if not. Im assuming LeedsMotorCo. is a body specialist etc. so he mite be able to do the work if neccessary. |
| Scratched speedo | Mattia | First Generation MINI Cooper S | 9 | Apr 9th, 2005 08:46 AM |
| Roof Scratched | maxsendq | First Generation Faults & Fixes | 0 | Apr 25th, 2004 12:35 PM |
| Some piece of human swill scratched my MINI | Kurtster | General Discussion | 8 | Feb 11th, 2004 07:31 AM |
| Scratched Rear | jasonfields007 | Maintenance & MINI Care | 8 | Feb 8th, 2004 01:07 PM |
| Yay! My Mini is here! But HELP my hubbie scratched it! | XSmall | General Discussion | 16 | Dec 15th, 2002 05:20 PM |
