Loose JCW Bumper Mesh Grill - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Exterior > Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
Old Oct 19th, 2009, 09:26 PM
Local Time: 03:13 AM
United-Kingdom Loose JCW Bumper Mesh Grill
Hi all,
I recently got a Mini Cooper S JCW auto (08) second hand and noticed that the front bumper grill is loose on one side. (see pic)
I realised that in order to fix it, i may need to remove the whole bumper and possible push the mesh grill from the inside.
If i were to take it in to BMW service centre, would they charge me (how much?) and will it be covered under manufacturer's warranty?
Yesterday as i was idling at the petrol station, the engine/car made a loud noise (sounds like high revs ie: as though i put my foot on the pedal) for 10-15 seconds and stopped.
That was the first time i experienced some sort of radiator fan noise since i bought the car. Is it normal? I did not have the air con on (if that helps).
Thank you in advance!\
Old Oct 19th, 2009, 11:20 PM
Murker1991's Avatar
United Kingdom Male View Murker1991's Nightfire Red & Body Color 2nd Gen MINI One Profile View Murker1991's Classified Ads
just a suggestion but maybe pull it forward with some thin plyers wrapped in clothe to be careful not to damage the grill?
Old Oct 20th, 2009, 02:18 PM
United-Kingdom
Thanks for the suggestion Murker1991.
I tried doing so. Unfortunately, there are no vents on the right side of the mesh. Only in the middle.
I hope BMW don't charge me a bomb when i send it in. Recently they charged me £40 to refit 2 deflectors which i bought (fitted under the front bumper).
Service / labour charge is a KILLER!
Old Oct 21st, 2009, 10:14 PM
Murker1991's Avatar
ahh.. well maybe jack up the car SECURELY dont want it falling on you and pushing it from underneath? bmw are extortionists i hate handing over money to the gready ****ers
Old Dec 1st, 2009, 01:46 AM
Local Time: 10:13 PM
Canada Male
Best trick, Use a flat head screwdriver, a small one and you can put it in from left to right and just apply a little pressure and pry it back into place. done it 100 times and if it is lined up properly. should just pop in. if u see it to be a little tough, sopa water and a squirt bottle to spray some to "lube" the pin in. good luck
Old Mar 10th, 2010, 03:22 PM
Local Time: 07:13 PM
Canada
Canada
Or, do what I did, bend a coat hanger or welding rod so it has a small hook on the end, hook it through the grille as far left as you can around one of the grille webs and pull. Snaps right back in, no damage.
Jamie
Tags: , , ,
jcw black mesh grill Murker1991 Second Generation MINI One 2 May 12th, 2009 04:12 PM
Mesh grill - need help yoni99 First Generation MINI Exterior 8 Mar 30th, 2006 10:23 AM
Mesh Grill ??? monkeynuts First Generation MINI Exterior 1 Apr 18th, 2004 06:29 PM
Black Mesh Grill Old School Jonnie First Generation MINI Exterior 2 May 7th, 2003 06:25 PM
Mesh grill alexcroft First Generation MINI Exterior 0 Apr 30th, 2002 11:42 AM
