LED Sidelights & Number Plate lights - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Exterior > Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
  #16 (permalink)
Old Mar 3rd, 2011, 12:49 AM
scotty01's Avatar
Send a message via MSN to scotty01
Local Time: 03:14 AM
Scotland Male View scotty01's Sparkling Silver & Body Color 2nd Gen MINI One Profile
usually just twist and pull, however mines had corroded so I had to take mines to a garage and they had to use grease to get it out yours might be the same.
  #17 (permalink)
Old Dec 16th, 2011, 07:15 PM
Belgium Male
Great sidelight LED's
Hi guys
We have a 2009 Mini convertable in Chlli red.
I have just changed the rather yellow side lights for these great LED's.
They just go perfectly with the xeons that we have.
See the difference!
Name:	IMG_4452 (Large).jpg
ID:	163003   Click image for larger version
Name:	IMG_4453 (Large).jpg
ID:	163004   Click image for larger version
Name:	IMG_4460 (Large).jpg
  #18 (permalink)
Old Dec 17th, 2011, 10:13 AM
Local Time: 02:14 AM
Yes the LEDs colour looks great.
I also did the same, plus added these special DRL strip LEDs that sit inside the gap between the bumper and bonnet.
Combination of both avoid canbus error or need of load resistor.
  #19 (permalink)
Old Dec 19th, 2011, 04:32 AM
BlueBeastie's Avatar
Local Time: 04:14 AM
South Africa Male
Quote: Originally Posted by mrlapou (original)
Hi Guys.. yes laugh, but I huffed puffed, but blow me down could not remove the front side light bulbs (located in the same light assy as the fogs).
Are/is there any tips / easy way to this?
You have to remove the bulb housing and then just pull the bulb out
  #20 (permalink)
Old Dec 19th, 2011, 08:18 AM
If that's the case, for better access remove the front wheel, pull off the power connector, then as advised in previous posting twist the connector base about 90 degrees (may require some pliers) then it's a matter of giggling the item out, being carefull not to dislodge bulb and drop it into the light housing. Grease O ring and shoulder before re-installing.
  #21 (permalink)
Old Jan 12th, 2012, 03:56 PM
Jungtony's Avatar
United Kingdom Male View Jungtony's Chili Red & White 2nd Gen MINI Cooper Diesel Profile
Hey mrlapou, those DRL's look cool,can you tell where you got them from and were they easy to fit
Tony
Chili Red Dooper
  #22 (permalink)
Old Jan 13th, 2012, 09:51 PM
With my countryman, when my side lights come on when unlocking they gradually light up. Would this not happen with led's?? Cheers.
Flashing led number plate lights crofty136 First Generation Faults & Fixes 8 Jan 18th, 2011 11:40 PM
Number Plate LED Lights Cooper-Works-McMen Second Generation MINI Exterior 3 May 10th, 2010 02:44 PM
number plate lights.... adam_Randell Second Generation MINI Exterior 4 Mar 4th, 2009 11:14 AM
led number plate lights jayminis First Generation MINI Exterior 2 Oct 2nd, 2008 09:14 AM
rear number plate lights not working? eddycooper First Generation MINI Exterior 0 Oct 23rd, 2007 06:00 PM
