Removing Aerial for R56 Roof Decal - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Exterior > Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
Old Feb 28th, 2013, 05:27 PM
Local Time: 12:40 PM
United-Kingdom Removing Aerial for R56 Roof Decal
Guys
I have bought a roof decal from a good company online. They have said the decal installer will need to remove the aerial to get the sticker on (Black jack style).
The installers are sign experts and wont touch the aerial only add the sticker.
1) Can I remove the aerial first? Then put it back when the sticker is on?
2) Is it hard and is there a how to?
Rob
Old Feb 28th, 2013, 07:14 PM
United Kingdom View AMAUTOS7's Classified Ads
When u say aerial do you mean the aerial base
I wouldnt advice removing the base - you will wreck it
If its just the long aerial bit then it just screws out
Old Feb 28th, 2013, 07:17 PM
yeah the base, surely the decal has to lay flat first then the base gets put back on top and screwed through?
Old Mar 1st, 2013, 09:28 AM
You have to drop the headlining inside and go in from the rear hatch to reach the aerial base fixings from the underside of the roof.
But Im sure a decent decal/wrap firm could easily trim to fit around it as they apply it without the need to remove it and then all the possible problems refitting it again?
Old Mar 1st, 2013, 11:06 AM
The decal company are going to now cut before sending, the whole may be a slight bit big but much easier
