Rear Fog light problem - MINI Cooper Forum
Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
post #1 of 3 (permalink) Old Jan 10th, 2014, 07:18 PM Thread Starter
Dermottdog's Avatar
Local Time: 05:29 PM
Hi people
I have a problem (only our 2nd ever) on our 2011 FJCW. The warning light to say that the rear fog light has failed is coming on every now and again - a yellow picture of a rear fog light with an exclaimation mark. When the picture goes out after about 10 seconds, it leaves the tiny triangle at the bottom of the rev counter showing. The triangle, as you know, is there until the fault is rectified. However, when I switch the rear fog light on, it lights up ok and the little triangle goes out. When I do a vehicle check when the fault is on, the fault log again says the light is faulty. After the fault has cleared, the vehicle check is ok.
I have removed the fog light bulb and the connections look clean. I will renew the bulb tomorrow, just in case it's breaking down for any reason.
Your thoughts please..... Thanks
Rob
Dermottdog is offline
post #2 of 3 (permalink) Old Feb 13th, 2015, 04:26 PM
Hi Rob,
Any luck solving this problem as I am having the exact same problem with my 2011 FJCW?
Many thanks
Anthony
anthonyjcw is offline
post #3 of 3 (permalink) Old Feb 13th, 2015, 05:05 PM
Local Time: 06:29 PM
Quoted: 53 Post(s)
Could be a flickering bulb, either loose in the socket, not very good contact, loose wire or the bulb is on its way out?
The Nun is offline
Intermittent Oil Warning Light Problem andyjshaw Second Generation MINI Cooper S 7 Nov 17th, 2015 12:22 PM
Removed Fog Light - How to disable warning? ibike365 General Discussion 0 Jul 26th, 2013 02:32 PM
Fog light Retro Fit Connection McKenzie General Discussion 0 Feb 15th, 2013 02:45 PM
R53 fog light surround black r53 General Discussion 0 Aug 15th, 2012 05:37 PM
