Towbar for 2010 mini hatch - MINI Cooper Forum
Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
post #1 of 2 (permalink) Old Apr 6th, 2014, 07:24 AM Thread Starter
Local Time: 02:04 PM
I have a 2010 mini one 1.6 3 door.
I need to go on holiday with my wife, daughter and dog and have no room for luggage.
I was thinking of towing a trailer for the luggage. But I can't find anyone who will list a towbar for 2010 mini one 1.6, they will only list a 1.4.
I can't see why there would be a technical difference. But I am picking up that there was some legislation change in 2010 about tow weight to car weight ratio so I don't know if it is not legal to fit towbar after 2010.
Anyone any ideas.
MiniArcher is offline
post #2 of 2 (permalink) Old Apr 6th, 2014, 11:33 AM
Local Time: 01:04 PM
Quoted: 39 Post(s)
I suggest this is because the towbar companies listings are out of date - the One was a 1.4 many years ago. I believe the One and the Cooper count as the same car for towbar purposes and what fits one fits the other.
You can confirm the maximum towing capacity that Mini allow by looking at the VIN plate in the left door shut. This lists four weights in kg in the following order:
- Gross Vehicle Weight (the maximum loaded weight of the car)
- Gross Train Weight (the maximum loaded weight of car and trailer combined)
- Front Axle Weight (the maximum loaded weight of the two front wheels), often with '1-' in front
- Rear Axle Weight (you can guess this one, can't you?), often with '2-' in front
Deduct Gross Vehicle Weight from Gross Train Weight and you have the maximum trailer weight. Mini may allow a higher trailer weight than this (ie, that can be towed by a car when it is not loaded to its own maximum) - look in the handbook for that.
There are some models that Mini has not bothered to approve for towing, such as S hatchbacks or all Convertibles/Coupés/Roadsters, so they have a blank line for Gross Train Weight (see photo) since that does not apply to a car not approved for towing.
However please note that the trailer that Mini says it is OK to tow and the trailer that your driving licence allows you to tow are two completely different things. The licence restrictions are now so complicated that you need to individually look up what you can tow, based on when you passed your driving test at
https://www.gov.uk/towing-with-car
If you just want to tow a small baggage trailer, which is likely to be much less than 750kg loaded, then none of this is a worry as you will be well below any trailer weight limits.
Angib is offline
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 06:36 AM
BMW Group to build new MINI Hatch at VDL Nedcar mab01uk MINI in the Media 0 Feb 19th, 2014 12:21 AM
Brands Hatch Mini Festival 22/23 June 2013 mab01uk Mini Events 20 Jun 23rd, 2013 11:03 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 07:11 PM
Brands Hatch Mini Festival DVD mab01uk MINI in the Media 0 Aug 19th, 2012 10:01 AM
