Bonnet scoop replacement question - MINI Cooper Forum
Second Generation MINI Exterior
Second Generation MINI Exterior 2006 - Present
post #1 of 6 (permalink) Old Jun 7th, 2014, 04:35 AM Thread Starter
Local Time: 10:31 AM
Hi all,
My R56 S needs bonnet scoop replacement as it is broken. I would like to replace by myself but I can only find 3 screws under the bonnet, one is "flower" shape screw and the other two are Philips. However, when I checked the Mini parts order site, the bonnet scoop fitting kits includes huge numbers of screws. Is there any fitting instruction I can find? I Google it for the whole day but seems none. Thanks!
vwillrocku is offline
post #2 of 6 (permalink) Old Jun 7th, 2014, 02:00 PM
Local Time: 11:31 AM
If you go to minigenuineparts.co.uk they do a bonnet scoop fitting kit for R56. (took less than 30 seconds to find on google )
Now
E39 B10 3.2 # 64 in Alpina Blue Metallic
R53 Mini Cooper S - GTT 220
Mr-P is offline
post #3 of 6 (permalink) Old Jun 7th, 2014, 02:45 PM Thread Starter
Thanks for your quick reply. However, I always know where to buy the fitting kit, what I don't really understand is how to remove and re-install the scoop.
post #4 of 6 (permalink) Old Jun 7th, 2014, 05:36 PM
marque is offline
post #5 of 6 (permalink) Old Jun 8th, 2014, 03:06 AM Thread Starter
Oh, thanks a lot! It really helps and I will try to DIY very soon.
post #6 of 6 (permalink) Old Jun 14th, 2014, 07:18 AM Thread Starter
Today I successfully replace the scoop, the only slight problem was the position of one plug and the under bonnet screw bias a little bit. But I can still get the job done within 30 mins. Thanks!
Tags: ,
Extended bonnet scoop Asif jcw General Discussion 2 Sep 4th, 2013 01:31 AM
Bonnet Stripes Question Reflexboy Second Generation MINI Exterior 1 Aug 15th, 2013 09:09 AM
Bonnet fitment question Ellies Mini General Discussion 4 Dec 4th, 2012 11:30 PM
Bonnet Stripes - Dealership Replacement JasonJay First Generation MINI Exterior 1 Aug 24th, 2012 02:47 PM
