I found no useful detail about removing the OEM roof mount aerial, so this may help someone :
The aerial is fixed with a clamp plate which has a captive 19mm nut and a tongue which fits into a groove in the aerial body.
You can undo this nut with a 3/8" drive 19mm socket on a wobble bar.
Carefully pull the headlining down appx 3" and you will be able to slip the 19mm socket into the nut.
A fraction of a turn will be enough, as teh nut is little more than finger tight.
Pull the aerial up through the roof and undo the connectors.
Refitting is the reverse of removal
