HELP... Juddering Engine After EML Fix - MINI Cooper Forum
Second Generation MINI One MINI One from 2007 - Present
post #1 of 1 (permalink) Old Feb 2nd, 2014, 06:47 PM Thread Starter
Local Time: 09:19 PM
DIY HELP... Juddering Engine After EML Fix
Hiya, my first post and don't normally post when there is a problem with my car but i am stumped with my Mini.
The car was juddering and the EML came on. So after getting it on the diagnostic machine i was told Coil Packs for cylinder 2 and 4 had failed and needed changing. So i did this and changed all the sparks for good measure and the car still feels like its not firing on all 4.
I have moved the coils around to see which cylinder isnt firing and it seems to be the second one...
The car feels fine to drive when at higher RPM (above 2000) its just juddering under that and doenst seem to be idling right so could anyone be able to point me in the right direction...
Thank You
Glover04 is offline
will forging engine parts fix oil consuming issue? genik Second Generation MINI Tuning 6 Sep 25th, 2014 01:59 PM
Mini engine dispute SarahH General Discussion 9 Dec 11th, 2013 11:39 PM
2006 S Engine for a Non S 2002 mikeroth First Generation MINI Tuning 1 Dec 10th, 2013 10:59 AM
Cracked engine block? Help please?! rhutch First Generation MINI Cooper 2 Dec 16th, 2012 11:24 PM
BMW three-cylinder MINI engine revealed mab01uk MINI in the Media 1 Oct 9th, 2012 11:42 PM
