Something badly bent, rear left. - MINI Cooper Forum
Second Generation MINI Suspension
MINI Suspension Late 2006 - Present
post #1 of 2 (permalink) Old Apr 19th, 2014, 10:40 AM Thread Starter
Local Time: 09:33 PM
So I've just taken my other halves 06 mini cooper convertible to have its wheel alignment checked as its been munching through rear tyres, specifically the edge, and the rear left was so far out they couldn't do anything.
Hopefully the picture of the readout has uploaded, but if not, the readings show as 2*13 camber and 2*11 toe, in other words the rear left is angled in due to hitting something.
Obviously I need to take it apart, or take it to a garage, but any ideas what is likely to be bent to cause it to be so far out of alignment?
Thank you all in advance.
a19tgg is offline
post #2 of 2 (permalink) Old Apr 19th, 2014, 12:40 PM
Local Time: 08:33 PM
Hi ya
I would first pull out and check your camber arm make shore there straight and the bushes are ok . They are very weak and suffer from corrosion.
Have a look around the subframe where they mount.
Also have a good look at the trailing arm bushes to they do wear
Has the car been lowered at all
Item 9 and 7 are what you need to check first
http://www.realoem.com/bmw/showparts...27&hg=33&fg=30
marque is offline
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 02:12 PM
knocking noise from passenger left rear side dessieb123 MINI Cooper Diesel 1 Dec 18th, 2012 07:29 AM
Small accident rear left wheel omri617 First Generation MINI Exterior 5 Aug 5th, 2012 01:55 PM
