| Second Generation MINI Tuning Tuning the second generation MINI Late 2006 - Present |
| LSD & ASC+T enough ?? Is LSD and ASC+T enough or should i go for DSC? Not being the most technically gifted when it comes to cars, I'm trying to decide whether i should go with the LSD and ASC+T or LSD and DSC? What are the advantages of DSC? Given that the R56 looks like its on stilts i'm going to drop the suspension a little! so will this make any difference to the choice to make? |
| LSD, traction control Don't know if this helps but I have a 2005 mini cooper s and I didn't go for the DSC. I just had the LSD installed. I never have the traction control on, every time I get into my car I turn it off as it is really annoying when it cuts the power when trying to make a quick get away from junction or traffic lights. Also if you are mid corner and need to accelerate out then it is not good when is cuts in as you could end up backwards into a fence,hedge etc. I cannot comment on the DSC system but I have found that the LSD is good enough to get the power on to the tarmac. Obviously if you put to much rpm on then you will get wheel spin but both wheels will spin opposed to one if the LSD was not installed. |
| Thanks Paul, What i mean in technically gifted, i mean understanding the technical benefits of the features. Not driving abilities. I am definately speccing the LSD for the R56 S. What i can't decide is whether to go for DSC as well. I'm not planning on any Track days, but do enjoy the odd spirited drive ![]() How does the DSC work? If its purely safety, then its worth going for. If its only a performance assistance, then no point! As you say its a major safety feature then i'll probably go for it. Cheers |
| Tags: asct, dsc, dynamic stability control, limited slip diff, lsd, traction |
| Asc & Dsc | BlackOutS | First Generation MINI Cooper S | 20 | Feb 14th, 2005 08:34 PM |
| ASC&T - retro fit question | Ratty | First Generation Faults & Fixes | 8 | Mar 2nd, 2003 10:43 AM |
| DSC/ASC & brake lights? | SPClark | General Discussion | 12 | Dec 24th, 2002 09:24 PM |
| Test Drive & ASC+T | hapaboy | First Generation MINI Cooper S | 4 | Jul 31st, 2002 04:02 AM |
