turbo timer, needed??? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Engine & Drivetrain Tuning > Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
Old Feb 22nd, 2008, 10:31 PM
Local Time: 07:30 PM
Please let me know if what im saying is correct in the following sentences!
There is no turbo timer needed for the Cooper S R56 because there is an electric water pump that is flowing water through the turbo for quite some time after we shut our cars off. So if i push my mini hard on a hot day, there is no need when i return home to have the engine running for a min or so (idle). Ill just turn of the engine as soon as i arrive and then let the electric pump to do the thing its supposed to do and stops by its own when it feels like it should!
Am i correct?
Old Feb 22nd, 2008, 10:57 PM
Local Time: 08:30 PM
United Kingdom View bob corbishley's Chili Red & White 2nd Gen MINI Cooper Diesel Profile
There is a run-on water pump but I would still let the car idle for a short while if I'd been giving it some beans. The big problem is the oil breaking down due to overheating so its good to let the oil circuit get a chance to cool off on light load before knocking the engine off.
Old Feb 23rd, 2008, 11:28 AM
Local Time: 09:30 PM
Greece
There is absolutely no reason NOT to let your car cool down for one or two minutes.
The oils must circulate and not remain hot in there, because this will harm badly the turbine.
So, just let it for one or two minutes, and you are done.
No reason NOT to do it.
Old Feb 23rd, 2008, 03:21 PM
Male View kevkbuk's Astro Black & Body Color 2nd Gen MINI Cooper S Profile
Depends on how you use your car I suppose but I've never thrashed mine then immediately stopped. I always have a period of slower driving when say returning home due to town traffic and lower speed limits.
I have never driven my turbo cars any differently to NA cars I've owned and never had a problem. Your only wasting petrol letting the car idle away IMO.
Old Feb 24th, 2008, 08:30 PM
caesar's Avatar
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
Am i correct?
In the old day's it was recommended that you drive slowly in order to cool the Turbo before parking. The Turbo on the MCS has a small pump that circulates water to cool it after the engine is turned off. In other words you have no need to worry
Old Feb 25th, 2008, 04:52 PM
Greece
We must not mess the cooling of the turbine with the cooling of the oil inside the turbine.
That is the reason to leave it for one or two minutes, no more.
Old Mar 1st, 2008, 02:00 AM
klint's Avatar
Ninja
Malawi
Best to let the car cool, but no need to tick it over unless you got a long enough to drive to give your car a good drive.
Old Aug 25th, 2008, 02:03 AM
Local Time: 03:30 AM
Australia View outlear's Laser Blue & White 2nd Gen MINI Cooper S Profile
Question is the run on water pump very quiet? I have only had my MCS a couple of weeks so haven't run it in yet. But I have never heard a pump running after I turn the engine off.
Old Aug 25th, 2008, 09:30 AM
matfrost's Avatar
A Total Mini Convert
Send a message via AIM to matfrost
England Male
If it is important on the S to let the engine idle for minute or two before turning it off, then when I pull up at traffic lights and the engine turns itself off automatically it must be doing itself harm?
I am sure BMW must have thought of this when they implemented the auto start stop, so I guess the water pump must be adequate to protect the turbo. So if you let it idle for a while you are just wasting fuel, and negating the whole point of the auto start stop?
Changed my Mini to a Clubman and my home to Total Mini
.com
Old Aug 25th, 2008, 09:44 AM
caesar's Avatar
CORRECT...........the cooling pump turns on/off automatically. The pump is very quiet in operation, all you can hear is a faint buzzing. When the car has been driven hard and you park it, the pump will run for quite a long period especially in hot weather.
Old Aug 25th, 2008, 11:01 AM
ThatsMe's Avatar
Local Time: 05:30 AM
Australia Male View ThatsMe's Astro Black & Body Color 2nd Gen MINI Cooper S Profile
My engine fan (thats what it sounds like) seems to run for up to 2 mins after i turn the car off after a bit of hard driving.
When everything's coming your way, you're in the wrong lane.
Old Aug 25th, 2008, 11:24 AM
caesar's Avatar
You are confusing the sound of the turbo cooler pump with the engine cooling fan. The fan will continue running for a period after the engine is stopped until the temperature drops. The engine cooler fan is much noisier than the turbo cooler pump.
Tags: , ,
HKS Turbo Timer T|tan|um First Generation MINI Tuning 0 Jan 14th, 2005 02:28 AM
First Timer-question NOLOGY First Generation MINI Cooper S 22 Aug 17th, 2004 03:27 PM
first timer annamac General Discussion 6 Aug 10th, 2004 10:35 PM
Longacre Hot Lap Timer kmickey MINI in Motorsport 0 May 30th, 2004 03:22 PM
turbo timer new Rest of the World 8 Feb 11th, 2004 07:07 PM
